Hello all . I have built a rb25/30 the car runs well enough and revs fine and smooth . The only problem is there is a top end noise . We think it's the lifter . Also have put lifter cleaner in , We changed the lifters taken them out and fully cleaned them. It got better, but was still there and slowly got worse. Now there is a consistent knock. No distinct area of the noise . We don't know if it had a restrictor or not . The head has the vct mod and all . Would any one know what the problem is or even what we could do . I'll also try up load a video on YouTube
https://www.sau.com.au/forums/topic/450206-rb2530-top-end-knock/
The vct oil supply supplies oil to the front cam bearing on non neo heads. So with no vct oil feed you have no oil to the front journal.
That's bad.
Deleting vct is bad as it loses response. People pay heaps to get vct onto RB26s.
Deleting the oil feed is worse as it removes the oil feed to the front bearing.
Why an rb20 cam? What happened there?
Edited by Ben C34
Oh just remembered, on th pre neo head you can drill out a brass plug in the front of the head near the inlet cam gear. That might be what the guy did before you?
Edited by Ben C34
I had a similar problem in my BMW e36. Knocking noise from the top near the rocker cover. Used a screw driver to my ear to try and pin point it but couldn't. Some people thought lifters. Turned out it was the water pump. Check yours, that may be it
Well I pulled apart the lifters and cleaned them all. But I never bleed them . So they would have been soft when I put them back in . Therefor making the slapping noise because they are bottoming out and slapping on the cam draft it self ?
Deleting VCT on a non-Neo head will not cause oil starvation to the cam bearings.
VCT on a road-only engine is probably a good thing to achieve broadest torque spread. On other applications, it is open to debate.
If you disassemble lifters, yes they have to be bled before installation. It is as simple as collapsing them so that they will pump full of oil without any air pockets.
Try using a piece of hose as a stethoscope to identify which one(s) are noisy.
Could be a weekend spent lifting the cams and lifters to give them some attention.
I'm reasonable sure the front cam bearing is fed via the vct oil supply, so blocking off the vct oil supply causes it to run dry I could be wrong of course!
I'm about to complete a rb3025 build and I blocked off the VCT oil feed as I'm not running VCT. Can somebody please confirm that blocking this feed off will starve the front cam bearing...
Cheers
Ps: sorry bout the thread hijack! Lol
Cheers
Check it yorself by blowing compressed air into the cam oil feed and seeing where it comes out, assuming that you have the head off. That way you will k ow for sure.
Problem is, I've already grub screwed the f**ker closed and assembled majority of the motor. Lol
Now you got me shitting my pants Ben...
Are the cams in? You could blow air through the oil galleries by blowing it into the cam journals.
I haven't used a pre neo head. The info came from my machinist who had seen the damage on a head from lack of oil.
Check this out.
http://webbersrbguide.com/index.php?option=com_content&view=article&id=89:rb30dettt-internal-a-external-oil-feed-mod&catid=50:rb30dettt&Itemid=29
Pay attention to second last paragraph.
Wow - I better investigate... I've pretty much out it all together without the manifolds. I'm spewing! I might speak to my machinist and see his opinion on the matter otherwise I gotta rip the head off...
Thanks for the heads up dude!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - there is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
