deleting the vct oil feed passage on the bottom of the head to build a 25/30 without running an external feed to the vct starves the front journal of oil, might work ok for a while as the heads get a stupid amount of oil up there, yet its not good for the cam, the way to fit this is to take out the brass plug from behind the cam gear, and cut it off at the part where it things out before getting larger again, and then reinstall it, this allows the oil galery to goto the front of the head, if you dont do this the oil galary is blocked before the front journal.
Back on this discussion, I forgot to post my findings... I attempted to remove that brass fitting and the prick wouldn't come out.
As a move of desperation, I bought an oil squirting bottle thingy and pumped oil down those two holes on the front journal and it pushed oil into the main oil gallery along the side of the head. Not sure why it worked but as I was able to prove to myself that oil traveled straight through, I decided not to modify that brass fitting!
It's a very strange and debatable issue and I believe the best way to overcome it is to confirm using an oil can whether or not oil travels to that front cam journal.
Thanks for the advice from all the guys on here...
When you say the main gallery you mean it was comming out the other cam journals and such? If not then where. As I've had one home built rb30 come into my shop with the front cam journal completely stuffed and he hadn't done that mod when building it, and on the 3 I've done I've cut it down and havnt had any issue. I'll need to look into it more on the next one I build
  • Like 1
I pumped oil into the front feed and oil went though into the oil gallery. Refer to the photo, if you look closely you'll notice the oil.
I was so confused because Ben managed to convince me that I needed to do that mod...
This photo shows the amount of oil that went through after 2 squirts!
Guys also forgot to mention, that my mechanic who also builds engine had a spare rb25det head in his workshop and that head wouldn't allow oil to go through that passage when I attempted the same test! It is such a confusing, yet concerning matter!
Wow.
So there are differmves with the heads!
As Scott said he has seen, my engine builder has seen it yet people say its no worries, and now you have proven in your case your head is fine......
Very interesting.
Good on you for checking as it could have ended badly, now it has let others know that the heads are different somehow!
  • Like 1
http://www.sau.com.au/forums/topic/251669-rb2530-rb30det-vvt-internal-oil-control/page-2
this page here shows the plug we talking about and theres some drawings to show where it cuts off oil supply, so im really shocked it wasnt needed in you case. amazing
My head definitely a series 1 rb25det head... The engine builder had no idea what type of head he had, said it was a drop off from a few years ago.
It's such a weird topic because sometimes it works out for people and sometimes it doesn't. I believe ultimately all people should check with an oil can. According to my engine builder guy, if the mod isn't needed then it shouldn't be done as the last thing an rb head needs is more oil to it!
I attempted this for hours man and the piece of shit wouldn't come out... Snapped a bolt in there and then tried using a tap bit and even snapped that in there. That was the point I raged and decided to test it for myself...
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
