deleting the vct oil feed passage on the bottom of the head to build a 25/30 without running an external feed to the vct starves the front journal of oil, might work ok for a while as the heads get a stupid amount of oil up there, yet its not good for the cam, the way to fit this is to take out the brass plug from behind the cam gear, and cut it off at the part where it things out before getting larger again, and then reinstall it, this allows the oil galery to goto the front of the head, if you dont do this the oil galary is blocked before the front journal.
Back on this discussion, I forgot to post my findings... I attempted to remove that brass fitting and the prick wouldn't come out.
As a move of desperation, I bought an oil squirting bottle thingy and pumped oil down those two holes on the front journal and it pushed oil into the main oil gallery along the side of the head. Not sure why it worked but as I was able to prove to myself that oil traveled straight through, I decided not to modify that brass fitting!
It's a very strange and debatable issue and I believe the best way to overcome it is to confirm using an oil can whether or not oil travels to that front cam journal.
Thanks for the advice from all the guys on here...
When you say the main gallery you mean it was comming out the other cam journals and such? If not then where. As I've had one home built rb30 come into my shop with the front cam journal completely stuffed and he hadn't done that mod when building it, and on the 3 I've done I've cut it down and havnt had any issue. I'll need to look into it more on the next one I build
  • Like 1
I pumped oil into the front feed and oil went though into the oil gallery. Refer to the photo, if you look closely you'll notice the oil.
I was so confused because Ben managed to convince me that I needed to do that mod...
This photo shows the amount of oil that went through after 2 squirts!
Guys also forgot to mention, that my mechanic who also builds engine had a spare rb25det head in his workshop and that head wouldn't allow oil to go through that passage when I attempted the same test! It is such a confusing, yet concerning matter!
Wow.
So there are differmves with the heads!
As Scott said he has seen, my engine builder has seen it yet people say its no worries, and now you have proven in your case your head is fine......
Very interesting.
Good on you for checking as it could have ended badly, now it has let others know that the heads are different somehow!
  • Like 1
http://www.sau.com.au/forums/topic/251669-rb2530-rb30det-vvt-internal-oil-control/page-2
this page here shows the plug we talking about and theres some drawings to show where it cuts off oil supply, so im really shocked it wasnt needed in you case. amazing
My head definitely a series 1 rb25det head... The engine builder had no idea what type of head he had, said it was a drop off from a few years ago.
It's such a weird topic because sometimes it works out for people and sometimes it doesn't. I believe ultimately all people should check with an oil can. According to my engine builder guy, if the mod isn't needed then it shouldn't be done as the last thing an rb head needs is more oil to it!
I attempted this for hours man and the piece of shit wouldn't come out... Snapped a bolt in there and then tried using a tap bit and even snapped that in there. That was the point I raged and decided to test it for myself...
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
