Hi guys I have 3 new bosch fuel pumps on them has these numbers
9 580 234 005 I cant seem to find any info on them in detail even after googling it.
I notice on it that it has 24v on it but from memory if im correct thats the max voltage for the pump. So it can still work at 12v or 14 for that matter.
Im planning on setting up my fuel system using these pump if they can work for my r32 gtr. Looking to support 800hp max for drag racing.
Thanks any help is appreciated.
https://www.sau.com.au/forums/topic/450234-fuel-pump/
There are some near perfect Chinese copies getting about these days, are you sure they are Bosch? Did you buy them from a reputable seller?
I think you are better off with a decent single pump off the surge tank, gear driven if you don't mind the noise. Have you looked at Weldon, Fuelab etc?
https://www.sau.com.au/forums/topic/450234-fuel-pump/#findComment-7417567
Well its stamped bosch on the pump mate. I did get them from a reputable supplier. And they were expensive. I have always wanted to go take a look at fuelab. But having these for a while and there brand new never used I wanted to know if they will work. The box the pumps came in are yellow with bosch stamps all over the box. they came from Germany not that it cant be faked from germany. Lol. Ill tell you how I got them
One of my friends work for TREX that makes container handlers called straddle carriers. On the straddle they use these pumps to lift fuel up 60f to the top machine platform where there is a small tank the supply the big diesel engine. I know it works at 24v and for diesel. Can they work for gas. Anf at 12 to 14 volts. Any specs avalible for them.??
https://www.sau.com.au/forums/topic/450234-fuel-pump/#findComment-7417579
Considering there is nothing from Bosch in a Google search, and all the hits come back as Alibaba, including one link selling the straddle carrier including said pumps direct from China... I have my doubts.
Even if they were genuine, running twin pumps without some way to tell if one is faulty is putting way too much faith in the pump, no matter where it's made.
https://www.sau.com.au/forums/topic/450234-fuel-pump/#findComment-7417591
Ok if its 24 volts why cant I use a 12vdc to 25vdc converter. ???
I wouldnt. Leaning your engineout and costing a fortune to replace/repair isnt cheaper then spending $200-$400 on a decent pump now is it?
I know you probably don't want to spend more money, but in the long term its better to have a pump that you can rely on.
https://www.sau.com.au/forums/topic/450234-fuel-pump/#findComment-7418183
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
