Hi, i have recently installed a 5 stud conversion on my r32. I am at the stage where i cannot seem to get the rear brakes to clamp the rotor!
all the gear off a r32 gtst including
-brake booster
-bm44 MC-
-4 pot 5 stir up front
-2 pot 5 stud down rear
I have alson installed some g tech brake lines.
After bench bleeding the MC for all extraction of air, all outlets flowed nicely.
Installing the MC onto the booster and connecting the brake hard lines i then start form the rear passenger brake.
Using the 2 man bleeding method (open bleeder, brake pedal down. Close bleeder brake pedal up) and repeating this method until a clear, air free stream. Going around all 4 callipers at least 5 times.
After this the pedal feel was completely soft 2 thirds (2/3) of the way down then you would hear a clonck and symoltaniously the pedal will become hard. This also happens when the rear calliper bleeder is open, opposed to when bleed ing the front calliper when the bleeder is open the pedal goes str8 to the floor.
After taking it up the street I found out only the front brakes were working. (when the car is on the same pedal feel present 2/3's down nothing then the front brakes engage).
After being thoroughly confused i took the calliper off the knuckle and getting some one to depress the pedal i saw the brake pads close after the 2nd or third press of the pedal, Which i would presume after the 1st pump making pressure then the brake pads would move, so I'm thinking this eliminates the calliper being seized. So it must mean there is air somewhere in the system.
So here are my questions.
WTF is going on???
Could there be air trapped somewhere in the callipers? or the hard lines?
Is the MC f**ked?
How man bleeds or amount of brake does it take to completely get all the air out and get a nice pedal feel?
HELP please,
Seems like you do indeed have air in the brake likes that run to the rear, when you changed the MC air tends to get into the steel pipe that goes into the MC and will take quite a bit to move all that trapped air all the way down the lines into the caliber and out the bleeder, I would suggest to re bleed the rear brakes some more and see if it comes good
You didn't inadvertently install the calipers upside down did you? As in, fitting the left side caliper to the right and the right side caliper to the left. This would put the bleed nipple at the bottom of the caliper instead of at the top. And make it impossible to get all the air out of the system. It's an easy enough mistake to make.
  • Like 3
You legend! the nipples are at the bottom right now, i will flip them, bleed them again and let you know. Giving that you said it is a simple mistake to make that sounds very much like a thing that i would do and have done.
Glad I could help.
Don't worry, I've had several cars come in to the workshop with the same issue. Always after the owner had worked on the car themselves, but even by some pretty mechanically minded guys. So like I said, it's a slight oversight. Swap the calipers around and it'll be good to go.
  • Like 1
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
