  • Replies 115
looks like i'll only have about 5-7 mins of footage after editing as there was not much left on the camera and i hadn't planned on putting something together. Any more footage would be appreciated. Thanks to my mate James for bringing the camera tho. Once i have got the video editing software from work and put something together, i'll work out how i can share it.
Hey Shonen!!!  That was a nice lil overtaking spree we did there! :(  And damn my ass is sexy! ;):) :)
hahha yeah it was good........for a moment i thought you got pissed off at me tailgating......hehe :D
haha yeah nice ass.......but i like ya old ass better !...
did you change your zorst ??? i could have sworn you had a different one last time i saw ya car....
once again GREAT cruise guys.....oh and apologies to tosh....that last move i did jumping in between you and the green s14....SORRY about that...
nice pics guys :cheers:
great cruise and I can't wait to get back to the hunter valley again!!!!
Shonen: no worries, I expected you'll be pulling in soon
if anyone has any feedback about the day, please PM or email me with it so I know for next year :cheers:
hahha yeah it was good........for a moment i thought you got pissed off at me tailgating......hehe :cheers:
Nah... wasn't pissed off at the tailgating! hehe... i kept tailgating others... oops!!! :
yeah... i did change the exhaust.. had the trust one... then the powergetter... now have the one thats on there at the moment... had to change it all cause of defects ;) i miss the sound ;) and i agree... my old ass WAS sexier :rofl:
LOL!!! i was wondering! Cause I overtook a good 5/6 cars or something and you didn't follow :rofl: i thought i had a buddy! :cheers:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
