of course, gotta move with the times. Does he really only have 1 sponsor?? http://www.fernandoalonso.com/en/patrocinadores/
Fittipaldi's JPS lotus 72(??) were the hottest looking F1 ever IMO... shape & livery. The latest attempt to revamp it was mehhh...
The 95T was better. Whatever happened to Ducarouge?
Anyway the current "Lotus" is just an attempt to cash in on a history that sadly died in 1994.
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
Hurry up
:mad:
That is BS!
Honda need to homologate their engine like the others had to first time around. They already have the advantage from having a full season of observing the technology of the other manifacturers and extended front end development of their engine.
Meh, the who engine fiasco is a joke anyway. I don't have a problem with the engines but its a joke how the whole thing is being administered. By putting them on a strict engine life cycle they are probably increasing the cost of the programs by a significant amount ...
Been asked and answered plenty of times but I never paid attention as it didn't apply to me... But what is everyone's pick for the best grandstand seating at the Australian GP?
Needs to have a screen in front of it which I'm assuming they all do...
Jones is the best bet IMO, on a sunny day the sun is behind you and you can see the cars coming down the front straight/pit exit and you get to see the right left combo with some overtaking at this corner.
World champion stand is good, I was there the last 2 years, Undercover and screen in front. Get to see pretty much 3 corners.
If you decide to go there, sit near the back. Its Melboure, and it will rain, you'll get wet in the front few rows. If not, sun is a killer there anyway. I think I sat 3rd from the back row last year, back row about dead centre of the grand stand would be the best, but probably sold out (stand B I think it was)
i enjoyed the brabham stand last year
on the inside of corner one
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
