RBR dug the hole ... no doubt.
But i say BS to chassis argument. Look at how RBR had an average chassis at the start of the year. They were allowed to develop which they have done and easily one of the best 3 going at the moment.
Argument could be made that they are the best.
Now engines...all but 3 teams are locked into what they
are given/bought. You could argue Williams get the same gear but this year they have been behind in spec and it is absolutely an engine formula. They tried to fix that issue years ago by freezing engines as a variable to within a few percent.
Now thats its a variable let others catch up just as they can from an aero or susp or brake perspective. Freezing it when it is a huge variable is silly as Renault and Honda teams are forced to sit out a season.
Good on Merc for getting it right...theybdeserve their championships....but imagine if other teams were banned from developing a blown diffuser...or an F-Duct etc....
Engine homologation has, is and always will be, shit.
Kimi is also taking a 5th engine this weekend. It's just not newsworthy for him because he's on half the points of his team mate and not in contention for anything.
Vettel is really only racing Rosberg anyway. Hamiltion's 66 point lead is basically insurmountable with 100 points left on the table in the 4 remaining races. He could DNF two of them with Vettel winning both, and still afford to finish 2nd to Vettel in the other two...
That's an awkward way of saying Vettel would have to win all the remaining races and hope Lewis DNFs at least two of them to even have a sniff! It's never going to happen.
Alonso will be running the new Honda PU all weekend too for the first time - only used in a prac session before. So it will be interesting to see if that goes any better than Jenson's old PU. Apparently this new spec engine introduces their direction for next year.
Edited by hrd-hr30
So will the English prat Palmer get his ass handed to him by Pastor? I doubt it but hope so. i like jim a tad more than James Calado which is really saying they are all tools from different shelves!
How guys like Frijns sit on the bench while...ok. Its the weekend and I should relax
Definitely to invested.. haha.
Let's be honest vettel isn't as big of a tool as homo is.
i dunno about that.....
TBH you have to have the sort of attitude they do to be a world champion. You can say what you want about homo but he can bloody drive.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
    • Gee she looks a bit rear heavy in that first pic! Sounds like a great project with the kids, but as I guess you know R series stuff is getting hard to find and pre that is pretty much impossible these days
