bah, that was just a gentle flop over after bouncing off the tyres. With modern barriers that wouldn't be an issue. Or you could move the wall back. But they'd obviously have more tarmac instead of the gravel trap these days too.
Well, they haven't got an agreement with Renault to supply unbranded engines yet... I imagine Renault would only go ahead with it if they are extremely confident their works PU will be clearly better. Renault engaged Illien at the end of 2014 to help develop their engine. I've read that Renault decided to pursue their own development path rather than use Illien's input...
Have RBR pilfered an ERS guru from another team or something? Otherwise they're probably on a hiding to nothing here.
Edited by hrd-hr30
Building engines probably isn't Renault's problem, it's the associated ERS and "Power Unit" rubbish that teams struggle with.
If the regulations were changed to allow more conventional type engines, fans would enjoy it more and the complexity of design and fabrication would be a lot lower therefore making the units cheaper.
No brainer really.
Edited by Nee-san
Talk is the single cylinder prototype yielded improvements. But as RBR were the ones that paid/introduced Illien they are disputing it is their IP and want to own it. I understand that is largely why Renault are kicking on with their own developments and it seems RBR will use the Renault motor as the basis with the Illien tweaks
Also, the talk is its the atual engine and turbo that is weak with the Renault and the energy recovery majic works well
I wonder if Louise can turn the switch back on next year or whether he will go to sleep now he has 3 x WDCs. Mercedes will have us believe development tweaks have moved the car in Rosbergs favour but surely Louise spending too much time in hotel rooms with C-grade rappers and F grade groupies has more to do with it
Nicole%2BScherzinger%2Bangry%2Bembarrass
I wouldn't be surprised if Hamilton has someone employed to teach him how to act to be liked... The way he answers questions now, initially it's what made me stop hating him as he seemed more humble, but these days it's like he's reading straight from a script..
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
