ok guys, so remember this is still only my 4th season of my obsession with F1 but getting my head around everything.
So the questions for you F1 gurus is.
1. the commentator said Riccardo changed to a combustion engine just before the race and will no doubt be penalised? Combustion as opposed to what? is he meaning no turbo??
2. Does red bull reserve the right to pull its middle finger up to Renault and place say a Ferrari engine in its cars for next race?
3. Will Kvyatt get Marko Helmutted for making the overtake so hard for Riccardo?
Best Pauline Hansen voice "Please Explain"
P.S. just saw on the last page a HD stream. I had a 480p free stream from the Dracula stream site. Wasn't too bad, its free so I cant complain.
1. Changed the combustion engine as opposed to changing the electric engine...I would've thought they were all paired as an entire unit but maybe not.
2. I'd say there's a contract in place for the entire season, and maybe beyond that as well, but there's also probably plenty of clauses for them to get out of it if the engine is a complete dud etc
3. At the end of the day he's allowed to race for position, but it's not gonna do him any favors holding up the main team, even if they are slower at times
Hamilton definitely sooks more than Rosberg over the course of a season.
And when the team tells you to stop being a dick and speed up, you know there's something to it...
He was definitely going slower than was necessary to make the tyres last the stint. You don't normally see people going 1-1.5sec a lap faster in their last couple of laps of a tyre stint - that shows just how easy he was taking it to back Rosberg into Vettel to ensure he had the fresher tyres at the end.
It is funny reading Homo coming out and saying "come on guys this is racing...it is meant to be fun " etc. He is the guy that most looks like he is having teeth pulled and sooking and being all passive/retarded in interviews. But, its great to see he is back in a good space for the moment and not sooking/sulking for a change
  • Like 1
RE point 1: they now have to say that someone has changed the combustion engine as them saying engine can be interpreted as the complete power unit with MGU-K and MGU-H along with the combustion engine. (MGU = Motor-Generator U, K=Kinetic (runs off/on the flywheel/Crank) H=Heat (Runs off the Turbo))
Changing a whole power unit is different to just the ICE (Internal combustion engine) I believe the teams are allowed 4 power units now per year and i think this means they can change the ICE and they will still have MGU-K...... etc left. As opposed to doing the power unit and using up 1 of each
I may be wrong but believe this is how it works
  • Like 1
89cal is right about the engine vs power unit. The "power unit" consists of 6 items: the internal combustion engine, mgu k, mgu h, energy store, turbocharger and ecu (and associated electronics). The 4 power units rule applies to all but the ecu. So what it essentially means is that you are allowed 4 ICE, 4 turbos, 4 mgu k, 4 mgu h and 4 energy stores. If you use 5 of any 1 of these items then you get a penalty, even if you have only used 1 of all the other items.
So there will be teams that are already onto their second or third ICE already but are on the first of the rest of the power unit.
That is why they won't just swap out a whole power unit each time something fails. If they blow an engine 1 race, and then a turbo the next and then a mgu k the 3rd race then it would count as 3 power units swapped if they changed the whole thing, or just 1 if they change only the damaged item.
BERNIE BEST STICK WITH TRYING TO TAKE HIS OWN PULSE! I hope behind the scence he is doing what actually matters with regards to the success of the sport.
http://www.autosport.com/news/report.php/id/118530
Anyone watch the WEC 6hr race at Silverstone and the 4hr ELMS race on teh Saturday? Cracking racing...and that is Endurance racing that is more excisting then a 60lap sprint F1 crace :(
Rosberg is doing worse than The iceman. Unless he improves very soon then this isn't even going to be a race against 2 drivers. Only Vettel is keeping Mercedes honest.
Dan has a terrible car, highlighted by his team-mate being nowhere and toro rosso getting up there.
oh right, thanks. I got my times mixed up. espn had it listed as "1800 local" and I somehow figured that meant 6pm sydney time. what a maroon!
both espn and formula1.com have buried the race times on this year's site revamps. they've both gone to a f**king awful mobile-friendly layout on their desktop site too. finally figured out to go to espn and click on the calendar then it show you.
meh, i'm not waiting until 12:30 to watch a racing formula I'm losing interest in anyway. if it's good I'll watch it tomorrow after work.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
