ENGINE/EXHAUST
Engine modifications
Block bored 20 thou oversize, decked and o ringed, fitted with forged ACL race pistons and rings
Scat H beam conrods, fitted with ACL race bearings
Crankshaft linished and deflashed oilways
Modified oil pump for greater flow
Heads have received a lot of work with machining, porting and polishing, cc’d, flow tested
1mm oversize Ferrea valves
Competition valve springs
Compression set at 8.5-1.
Inlet manifold has been match ported to the heads and the upper plenum.
JECS 1000cc injectors
Sard fuel pressure regulator and gauge
In tank Sard fuel pump
Custom surge tank and a Bosche 044 pump fitted underneath the car
Custom fuel cooler,
Braided fuel lines
Motorsports connection fuel filter
Battery has been moved to the boot area sealed in a battery box fitted with an isolation switch
Selin twin AFM translator
Twin Apexi power air filters
Series two power transistor unit
Spitfire coilpacks
Engine earthing kit
Modified crankcase ventilation with catch can
2 x GTX 28/63 ball bearing turbos
Recently changed from
UAS custom 600x300x90 front mount intercooler toBDE (Brett Dempsey Engineering) slimline engine mounts to allow for:
Complete 2.5in intake to turbo to intercooler to throttle body piping upgrade
Massive 2.5 inch in and out side mount intercoolers
Blitz dual SBC controller
(Jim Wolf Technology) JWT 400+ wild Cams
BDE (Brett Dempsy Engineering) modified Intake Cam gears
Tomei adjustable exhaust cam gears
A new set of hydraulic lifters fitted with shims has the motor running nice and quiet
Turbosmart, BOV’s
Ross Racing harmonic balancer
Gates blue belts turning the equipment over.
Engine management is by Nistune
56mm Alloy Radiator
72 plate external oil cooler
BEE*R rev limiter
RARE Final Flag polished throttle cable cover (1 actually have 2 of these)
Exhaust
Custom 5 bolt, divorced dump pipes
AMS exhaust manifolds
3” system through hi flow cats, and pair of Varex adjustable Mufflers
DRIVELINE
UAS six button single plate clutch
X-Treme chrome molly lightened flywheel
Chrome molly one piece tailshaft.
Richmond leader diff gears of 4.11 ratio
SUSPENSION
Bilstein PSS9’s coilovers
Powertrix front upper control arms
Powertrix front lower tension rods
Tune Agent rear camber
Tune Agent traction arms
Energy suspension bushings all round
Nissan front strut brace, one of only two in Australia
UAS HICAS lock out
BRAKES
Front,Stop Tech ST-40 calipers big brake kit
332 mm slotted, curved vein rotors
Braided stainless brake lines
Ferodo 2500 pads
Rear, Reliance Edge 297mm slotted rotors
Ferodo pads
Stone shields have been removed and tubular ducting has been fitted for extra cooling
WHEELS and TYRES
Choice of:
19x8.5 and 19x9.5 Lenso gt05 monoblock
18x9 and 18x10 Gram Lights 57F-Pro
Also available is a pair of stock 16” wheels fitted with Mickey Thompson ET street radials for those nights at the drag strip
EXTERIOR
2000 model urethane front bar
2000 rear tail lights
UAS fiberglass vented bonnet
Modified nose panel
UAS rear wing
UAS enclosed rear bar fitted with Perspex diffusers.
Ab-flug Areo mirrors
Custom made Miracle Zed Motors vented air guides for improved cooling to the radiator.
A HID headlights
INTERIOR
Recaro SR3 driver and passenger seats on Z32 recaro rails
Stock gauges have been replaced with el panels giving various shades of blue
Defi triple set, oil, water temp and pressure
Pivot boost gauge
Apexi turbo timer
Twin AEM wideband AFR gauges
Boarder racing gauge hood
Kenwood head unit with four kenwood 5” speakers
Terrano chrome door handles
Leather 300zx logo handbrake boot
Leather 300zx logo shift boot
2000 model gear knob
Leather trimmed doorcards, glovebox, center console etc
535.9RWHP @ 22PSI on BP98 with heaps left. At last tune we didn't even get to start bringing the timing back in when we had spark issues.
Left still to install is a HKS DLI ignition amplifier to fix the spark blowout.
  • Like 3
https://www.sau.com.au/forums/topic/451080-mikes-z32/
Thanks mate, I cant take all the credit for this one, bought it with engine built, just improving on it ;)
After building my old red zed and then getting defected (and subsequently parting it out) I wasnt going to do the whole lot again from scratch
https://www.sau.com.au/forums/topic/451080-mikes-z32/#findComment-7433398
Scored a HPC coated plenum with 55mm throttle bodies the other night. Been looking for a throttle body upgrade to complete the breather mods for a while now :)
Also I still have to sort of the ducting to the side mounts.
https://www.sau.com.au/forums/topic/451080-mikes-z32/#findComment-7433582
Becauseracecar
Because v6, 2 banks, 2 intakes, 2 exhaust manis. Already noticing some variations between the 2. Particularly at idle and light cruise. Not small variations either. Need to swap the sensors over and see if the readings swap also. Hopefully they do and its just a sensor on the way out.
https://www.sau.com.au/forums/topic/451080-mikes-z32/#findComment-7434729
So I removed the plenum on Sat, to swap over for another with larger throttle bodies.
Got it all back together Sat night (before the cruise on sunday) and couldn't get the idle down below 1500rpm. I am assuming that it is the butterflies on the new throttle bodies that are leaking :(
Going to have to swap them out again so I can at least enjoy driving the POS over the holidays.
https://www.sau.com.au/forums/topic/451080-mikes-z32/#findComment-7444250
So after boost leak testing everything, in sections, all I found was a pin hole leak in one of my new hardpipes. Other than that it is tip top. Idle issues seem to have been resolved with a simple TPS reset. Voltage was correct, but wasn't getting a throttle closed signal.
Haven't test driven yet, pointing to should be good tho!
https://www.sau.com.au/forums/topic/451080-mikes-z32/#findComment-7446320
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
