  • 3 weeks later...
  • 1 month later...
Put the headlights in, struts back in and wheels on. She currently is running, however a bit rough. It seems to be smoking a little bit, as well as idling too high. Will check the timing, but are there any other suggestions on what this issue could be? bad fuel?
  • 4 weeks later...
  • 3 weeks later...
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
