BNR32 Genuine C's Short Shifter - Used and comes complete.
Perfect working order, shift bush is fine.
A Discontinued item a while back now.
A more solid shift feeling and 30% shorter stroke to OEM
The best short shifter ever made for the GTR
$280 +postage
https://www.sau.com.au/forums/topic/451109-genuine-cs-short-shifter-bnr32/
Hi Richard,
I'll take this please since it includes the whole kit (ie plate, plastic insert, fingers that spread out from each corner)?
I'll need your details once more.
Kind Regards,
Terry
Besides being a shorter shift between gears Like around an inch or so to neutral. So maybe 2-3" between 1-2, 2-3, 3-4 etc..
It is firmer than the OEM (ie. not as loose feeling)
In a nutshell it is more direct feeling.
You don't miss gears and it stays in gears. It's not hard in to or out of gear but firmer and shorter.
Good for spirited drivers, driving enthusiasts and your race car driver. (I am getting lazy)
You don't throw it into gear, you move it into gear.
Think of paddling through air and paddling through water
If you have an issue with your GB or clutch I'd dissuade you from installing as it will amplify the issue.
Hope my explanation is helpful to all
Edit: Why would I let it go? Seemed a good idea at the time when I got home. I went OEM and the GTR feels less of a race car
although I am having second thoughts - hence why I haven't bumped it up
I checked the price on the Nismo shifters to price mine - Oh my son of rajab
Edited by Sinista32
Terry. When you get this. Can I loan the 2 round pieces on the left for the boys to use as reference to produce? I have the shifter. But am missing that 2 pieces.
*yawn*
The metal ring will be easy.
BUT the plastic washer will be the gotcha.
It's not simple by any means, it's unique underneath, although you may be able to simplify something (not sure).
Terry the 2 brass coloured "fingers" aren't in the box.
Will need to ask my Mech on Monday morning. I'll get back to you.
Terry, et al.
Unfortunately my C's Short shifter does not have the "brass fingers" (in the picture above), and did not have them in my GTR :glare:
Sorry for the hype and inconvenience. Withdrawn from selling.
Richard
Hey Des, I'm happy to send the metal ring up so you can replicate and then send mine back mate. Not a problem.
The plastic one I found out today is stock (OEM). needed for all shifters to mate up to the box. Your existing shifter will have one :)
Edit: Called Andrew @ Kudos. The plastic ring by itself is PN# 32875. Delivered to you would be under $20.
These metal rings are only for the short shifters. Best borrow mine for measurements.
Question for you.
Does your short shifter have the 2 brass coloured half moons or 4x allen key bolts and 4x nuts welded on square washers ?
Edited by Sinista32
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
