Hi ppls
In your experience, would there be a lot of diference between the following (Assume the Cat is a Batmbl big one and the Exhaust is a Fujitsubo Power Getter):
Standard Dump Pipe with Blitz front pipe.
Split Dump Pipe and Blitz Front Pipe.
Batmbl combined Dump and Front.
CESRacing full split Dump and Fron combo with wastegate gases joining rest of exhaust about 4-500 mm down the line.
I'm torn you see.
I have the Standard Dump with Blitz Front, and I'm wondering if its worth the money to upgrade the combination...
All help appreciated.
https://www.sau.com.au/forums/topic/45114-dump-and-front-pipe-combinations/
Guest Robo's
In your situation i would be definately upgrading to a split dump and joining to your Blitz front. Your exhaust can only flow as good as your first restriction and i believe it would be in your stock dump. Even the BATMBL front pipe is bigger than the stock front.
I have the BATMBL dump. but if i could get my hands on a split dump i would love to try it as when the wastegate opens there would have to be some turbelance with the exhaust turbine which doesnt help flow.
Bastard.
I want one.
Wanna do a comparison thing for us....
A dyno run before fitting anything, a dyno run with the cat back, and a dyno run with all the bits.
I'll pay for one run as a service to SAU..........
Or maybe a nice workshop is reading this and would help us out by not charging us four runs............
Anyone?
This is interesting, and I am all for a free flowing exhaust... BUT my GTR with the HKS GT2530's and everything that goes with, makes the same as others with the same mods. However I don't have aftermarket dumps and I'm still using the stock cat, the rest of my exhaust is aftermarket. Yep! I'm still using the standard "big time restrictive dumps"... :confused: well so am I.
There's the argument that:
- split dumps are better because they split the gases
- then you have HKS split which are only 150mm long "similiar to CES splits", but this is apparantly not effecient, and some will say you need the TRUST combined front pipe & split dump where the split meets around 400mm down rather than 150mm like the HKS.
- then you have companies like mines who have a dump with no split just a big muther opening..
- then you my tuners tell me save your dosh because the gain on dumps is very minimal, based on dyno testing.
still :confused: ..hmm so am I ! Didn't mean to throw this at ya. :)
Yeah I'm up in the air about it too.
Looking at the R34 cast dump, it can only be restrictive!
But Hypertech told me that there is very little difference also. Maybe 4 or 5 at the top end.
But surely, response would be better?
I'd really like to see the Boost Curve with diffent combos on......
I'd say on the stock boost you would find little gain with the stock dump, but the response would likely change. At higher boost there is a definite change with the BATMBL style in the midrange and the exhaust note..
I'd sell the expensive engine pipe and probably pay less for the combined dump pipe and come out ahead. They are easy as hell to fit but make sure you use anti-sieze paste on the threads.
In reality, when you look at the turbine outlet and the wastegate outlet diameters I see little need to go split on the standard turbo. There is a definite flow impedance designed into the stock dumps however.
Later down the road I will probably be putting a to4 on and at the moment just have a cat back on a 33gtst. I am in the same sorta boat as bass junky Most cost effective is dump and front in 1 (non split) ie. batmbl or flyn and is CES wank factor for the price (How much did you get urs for Daz) ? I can get a 3inch front pipe cheap but split dumps r still expensive. What do u guys reckon i should go with? Maybe getting a local exhaust shop to have a look and give me a quote on making a split one up. Dandenong exhausts made a nice one for a friends rex.
sorry to hijack thread :(
Hi ppls
I'm torn you see.
What about a HKS dump pipe?
Crazo
That's what I'm talking about.
they sell for over $500 new.
At that price, would be better to sell my front and buy the CES racing one.
Decisions...
Enrico... Ultimate Performance Imports have an R33 HKS Split Dump pipe on their page for $350.
Wont fit an R34, but will fit yours.......
Sorry of rthe hijack but I've got a custom stainless split dump pipe for sale if anyone's interested. Was only used for a few months before an engine rebuilt and other mods made me change. Asking $250 but open to offers.
Pm me for pics and details.
I'm not fully sure of where it was made because i bought it off INASNT when i bought his turbo at the end of last year. The thread for the dump is still here but the dump is not as shiney now due to use, still the same part tho in good condition tho.
http://www.skylinesaustralia.com/forums/sh...light=dump+pipe
    • Block bump. $400. As above cyl 6 needs bore or sleeve.
    • I would think making the argument that the travel is limited by a spring flexing against a spring perch as "the same method". Later on in the document they do state that the spring can't bind on full bump travel and cannot come loose in full rebound travel as well. (which is all very sensible). The laws are actually pretty sensible and reasonable. It's just that the people who enforce and check them don't actually read them or know them accurately. "Oh, coilovers? Instant fail mate. Don't even need to look at it." - Guy who will be instantly reported by me. There is probably merit to people who do get defected for height also get defected for the suspension in that state that allows it. I did never consider the people who are complaining about coilovers being picked on are also running around at 50mm off the floor.
    • I think given SAU's knowledge of E85 we can strongly conclude that 10% ethanol in almost any situation is entirely fine. Almost all of the myths against E85 were overblown, let alone E10.
    • From your link See bold text, is this referring to damper settings, if so that may a issue for "some" inspectors, I cannot see aftermarket coilovers having the evidence that "must be available that its functional performance is equivalent to the original" Maybe just remove the adjustment knows and hope for the best???? Meh 5.2 Suspension travel In all instances, modifications to a vehicle’s suspension must ensure the integrity of the system and not compromise the ride quality. At least two thirds of the original suspension travel should be maintained in both directions (rebound (i.e. extension) and bump (i.e. compression)), and rebound must be limited by the same method used by the vehicle manufacturer or if this is not practicable due to the nature of the modification, an equivalent method. If an alternative method is used, evidence must be available that its functional performance is equivalent to the original.
    • They actually don't - They adhere to VSB14 rules just like Victoria. The rules are against CABIN adjustable height, and it quite clearly states that the height has to be within parameters. I asked the VASS engineer to confirm this when I got my car engineered and they refused to engineer the coilovers because they didn't meet the requirements for requiring engineering. (mine are height adjustable.) People "Not wanting to bother" with "Actually reading/knowing/adhering to the rules" should result in fines and immediately losing the ability to issue blue slips and/or RWC's in Vic.
