Hi all,
I can't get my consult interface to work and I suspect a dud ECU consult interface. It's a S2 RSFour. I have checked it has 12V ignition connection and a good earth, and RX & TX wire continuity from the pins on my consult interface to the pins on the board. I have tried two different consult interfaces which work in other cars. So it must be the ECU - argh.
I only have a 2WD ECU to swap in and test (both cars are auto though, and S2). Is anybody familiar enough with the ECU pinouts to know whether a 2WD ECU can be safely connected to a AWD ECU?
I suspect it will be OK, because from a quick inspection it appears as though the only connection to the ATTESA system appears to be "integrated control signal (multiple communication)" which sounds like data to me - hopefully disconnected in the 2WD ECU?
I have been going by a R34 ECU pinout. I don't know if it's different for stagea.
Anybody know if it will be safe to test the 2WD ECU in the 4WD car?
cheers
DaveB
https://www.sau.com.au/forums/topic/451415-2wd-ecu-in-4wd-stagea/
Should be fine Dave. Main differences are between manual and auto but in the Stagea there appears to be no difference between 2wd and awd. The only thing is traction control so depends where you got your 2wd ecu. It should definitely be perfectly safe to plug in and try.
Yes, I wonder about that too. The R33 ECU definitely does - it's pin #56:
On the R34 system(s), I suspect it's pin 79 "ECM TCM, TCS/ABS integrated control signal [multiple communication]", which sounds like a data line. Matt from Nistune also told me there was programming in the ECU which was different for auto and 4WD. But that was a long time ago, with an older version of the type 4 boards.
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
