I have a boot leak down the sides of the boot from the edge of the rear window down to the tail lights. along that seem on both sides there are multiple leaks. I've reduced it with silicone to seal the gaps but still get through a little bit. I've stopped about 95% of the water.
Just wondering who i can go to for a permanent fix instead of a temporary fix. I think i have diagnosed the problem. Should i go to a panel beater or smash repair? or do i get someone to weld it?
It's not a huge problem but i can't put the interior in my boot because it gets nasty and wet.
My problem is similar to this guys video. i did the same thing as him but with a different product
Any help will be appreciated, cheers.
Edited by SkylineR33RB25
https://www.sau.com.au/forums/topic/451762-r33-boot-leak/
Pull the boot rubber off the boot opening, silicon the channel and then push it back on securely
Pull the tail lights out, silicon and put back in firmly
next day hop in the boot with a torch and get some one to spray water all over the back and check for leaks
Edit: Oh and seal all rust off from the oxygen if you have any
Edited by Sinista32
  • Like 1
https://www.sau.com.au/forums/topic/451762-r33-boot-leak/#findComment-7444434
It's not coming from the rubber seal around the boot it's coming from where the metal over lays
watch the video and look at where he is putting his sealant. and it's leaking from the top. up near the windscreen down to about half way . it's def not coming from the tail lights. it's drain perfect from there.
I highlighted in red where it's leak from in paint http://postimg.org/image/ylf6uk5az/
My question is who do i go to, to get it permanently fixed?
https://www.sau.com.au/forums/topic/451762-r33-boot-leak/#findComment-7444442
There is a great thread about this and has helped me and multiple other people.
The seal at the base of the window. The one with screws is a culprit. Pull it off and silicone.
The tail lights leak. Pull them out and reveal.
The bolt holes for the boot. There where it mounts to the guards leak as well. Silicone all those areas and You should have solved it.
https://www.sau.com.au/forums/topic/451762-r33-boot-leak/#findComment-7444449
That's where it's coming from highlighted in red ^^^^ click that link
It's coming from where the metal overlays. very small gaps in there. I can see it dripping from about half way so i don't think it's as high up as the base of the window
I can see it dripping into my boot when i fill the gutters up (the side of the boot) with water. and when i soak up the water from where i highlighted in the gutters it magically stops so it has to be coming from there.
Edited by PranK
Fixed underlined text.
https://www.sau.com.au/forums/topic/451762-r33-boot-leak/#findComment-7444456
My goodness. The seems will be deceiving. It will find one point of entry and then find the path of least resistance to the exit.
Oh btw I got quoted over 1 k to get the boot welded and painted.
I guarantee that if you chisel out the old filler you will find where it enters because there will be a rust spot.
The seems are not welded. They have this type of putty filler that ages and cracks
https://www.sau.com.au/forums/topic/451762-r33-boot-leak/#findComment-7444517
Can someone recommend a sealant.
I currently use Silastic. silicone rubber from autobarn in a 75g tube. I need something bigger like selleys. I'm going to disconnect my boot and do it properly.
Should i use selleys silicone? Would that be the best thing for the job?
https://www.sau.com.au/forums/topic/451762-r33-boot-leak/#findComment-7449773
The product that I have used a million times in boats of both aluminium and fibreglass is Sikaflex. Its nutso once it sets.
Note, to get it to bond well, you'll need to really scuff the paintwork, or it just wont bond properly. Hit it with a wire brush on a drill or a dremel and then apply it.
Also, Keep it dry for a few days. Rain and storms this week, it you dont have a garage then just wait.
  • Like 1
https://www.sau.com.au/forums/topic/451762-r33-boot-leak/#findComment-7449893
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
