I have a boot leak down the sides of the boot from the edge of the rear window down to the tail lights. along that seem on both sides there are multiple leaks. I've reduced it with silicone to seal the gaps but still get through a little bit. I've stopped about 95% of the water.
Just wondering who i can go to for a permanent fix instead of a temporary fix. I think i have diagnosed the problem. Should i go to a panel beater or smash repair? or do i get someone to weld it?
It's not a huge problem but i can't put the interior in my boot because it gets nasty and wet.
My problem is similar to this guys video. i did the same thing as him but with a different product
Any help will be appreciated, cheers.
Edited by SkylineR33RB25
https://www.sau.com.au/forums/topic/451762-r33-boot-leak/
Pull the boot rubber off the boot opening, silicon the channel and then push it back on securely
Pull the tail lights out, silicon and put back in firmly
next day hop in the boot with a torch and get some one to spray water all over the back and check for leaks
Edit: Oh and seal all rust off from the oxygen if you have any
Edited by Sinista32
  • Like 1
https://www.sau.com.au/forums/topic/451762-r33-boot-leak/#findComment-7444434
It's not coming from the rubber seal around the boot it's coming from where the metal over lays
watch the video and look at where he is putting his sealant. and it's leaking from the top. up near the windscreen down to about half way . it's def not coming from the tail lights. it's drain perfect from there.
I highlighted in red where it's leak from in paint http://postimg.org/image/ylf6uk5az/
My question is who do i go to, to get it permanently fixed?
https://www.sau.com.au/forums/topic/451762-r33-boot-leak/#findComment-7444442
There is a great thread about this and has helped me and multiple other people.
The seal at the base of the window. The one with screws is a culprit. Pull it off and silicone.
The tail lights leak. Pull them out and reveal.
The bolt holes for the boot. There where it mounts to the guards leak as well. Silicone all those areas and You should have solved it.
https://www.sau.com.au/forums/topic/451762-r33-boot-leak/#findComment-7444449
That's where it's coming from highlighted in red ^^^^ click that link
It's coming from where the metal overlays. very small gaps in there. I can see it dripping from about half way so i don't think it's as high up as the base of the window
I can see it dripping into my boot when i fill the gutters up (the side of the boot) with water. and when i soak up the water from where i highlighted in the gutters it magically stops so it has to be coming from there.
Edited by PranK
Fixed underlined text.
https://www.sau.com.au/forums/topic/451762-r33-boot-leak/#findComment-7444456
My goodness. The seems will be deceiving. It will find one point of entry and then find the path of least resistance to the exit.
Oh btw I got quoted over 1 k to get the boot welded and painted.
I guarantee that if you chisel out the old filler you will find where it enters because there will be a rust spot.
The seems are not welded. They have this type of putty filler that ages and cracks
https://www.sau.com.au/forums/topic/451762-r33-boot-leak/#findComment-7444517
Can someone recommend a sealant.
I currently use Silastic. silicone rubber from autobarn in a 75g tube. I need something bigger like selleys. I'm going to disconnect my boot and do it properly.
Should i use selleys silicone? Would that be the best thing for the job?
https://www.sau.com.au/forums/topic/451762-r33-boot-leak/#findComment-7449773
The product that I have used a million times in boats of both aluminium and fibreglass is Sikaflex. Its nutso once it sets.
Note, to get it to bond well, you'll need to really scuff the paintwork, or it just wont bond properly. Hit it with a wire brush on a drill or a dremel and then apply it.
Also, Keep it dry for a few days. Rain and storms this week, it you dont have a garage then just wait.
  • Like 1
https://www.sau.com.au/forums/topic/451762-r33-boot-leak/#findComment-7449893
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
