Been on here a while, don't post very often, but lurk around.
I currently have Rays Engineering CE28N's on my 34GTT, which I believe are 18x8 and 18x9 unsure of offset.
10470912_10154206675295231_6558176008423
I am thinking about buying new wheels but I am unsure of what offset to fit, and if I can fit under the guards. I am thinking something a great deal more aggressive
Keeping in mind my guards have already been rolled, in Japan.
Was thinking of getting these Rota Grid-R's in these offsets, but perhaps there is a better suited offset on the website.
18x9.5 +18 front
18x10 +15 rears
http://www.rotawheels.com.au/wheels/rota-grid-r
Would like similar fitment to this, maybe perhaps slightly less aggressive.
Nissan Skyline R32 fitted with ROTA Grid R 18 x 10, 5x114.3 +15 Cosmic Blue
My question is how far can I push the offsets?
Also will 18x10's fit under my R34GTT, or is that pushing it too far for the rear, and perhaps 9.5 is too much on the front also?
Cheers in advance,
Michael.
Edited by Illest
https://www.sau.com.au/forums/topic/451782-r34-gtt-wheel-offset-advice/
There is a huge thread dedicated to offsets for skylines here - http://www.sau.com.au/forums/topic/84208-wheel-sizes-offsets-for-skylines/
But in short, the 10+15 will be too wide unless you plan on aggressively flaring your guards. The 9.5+18 will still be very aggressive, but if you want to give up some function for form, camber will make them fit. I have 9.5+20 with around -1.5deg camber on the fronts and they still poke around 10mm.
Thanks for the reply mate, I had checked out the other other forum but didn't find anything close to the specs I was looking for.
Yours sits pretty well!
9.5" will be the way to go then, with +18 or +15 offset, this whole business confuses the hell out of me.
Cheers,
Michael
Edited by Illest
Basically, the lower the offset (the +18 part), the FURTHER out the rim will sit. So if we compare 9.5+30 and 9.5+10, the +10 will sit 20mm closer to the guard than the +30.
And just to confuse you, this number is dependent on the width of the wheel - so 9.5+22 is the same as 10.5+34 (as you are adding an inch of width, the offset is 12mm higher because 1 inch = 12.7mm)
Use this website - willtheyfit.com to chose the offset right for you. There is plenty of information on that thread, you are not looking hard enough.
Cheers,
Michael
Judging by your profile, what you want is the lowest offset with the widest wheel width, combined with the narrowest tyres size.
SO like a 185 wide tyre on a 10.5" wide wheel, because it'll match your bumhole stretch.
Complete shot in the dark, but did/do you know someone called Micheal Tran?
Mate to start with take your current wheel off & your offset should be stamped or written on the inside and width. Then go online and find a offset calculator, it will asked you to put in your current specs then it will tell you were your new wheel specs will sit. Remember if it's not aggressive enough you can always add spacers later. But you can't go back .
    • Yeah pretty impressive hey, good to see quality products not over-shooting their prices. That's what drew me to buy the hypergear turbo, just a shame I've never got the chance to see it in action
    • Thank you GTSBoy and MBS206 I have done the compression test with the motor out of the vehicle, reason for the test was to see if I needed to remove the head and do rings etc while its out. I'm in the process of respraying the vehicle and tidying up a few things. Story behind it all is I've just purchased the skyline and it was running when I got it, never drove it on the street though as I wanted to pull it down and do it all up again before registering it. the gentleman I purchased it from told me the motor has a forged bottom end and has a decent tune through it but I was going to pull the sump off anyway to see if it is a forged bottom end. that's why I thought id do a compression test beforehand.
    • Man, I'm kind of amazed that the price of the turbo has not changed in 7 years. Everything else is inflating beyond reason, but not this? Good on Tao / hypergear I guess? Anyways, good luck with the sale!
    • I'm selling my brand new, in the box, never used Hypergear ATR45 - and I had some additions I paid for a few yrs back when I purchased it. Never ended up having the rest of the money to add all the mods at once, so I just ended up slowly selling each part. I originally had it internally gated, with the dump pipe, however I found it was incompatible with what I was going to use it for, so I contacted (I think Ken) from Hypergear, and he and I messaged back and forth & he got me to ship the turbo back, where they modified it & made it externally gated, and gave me the 5 bolt dump pipe attachment for custom welding. (Photos below) This turbo like I said has never touched the inside of an engine bay, it's completely brand new, never used, been sitting in the same box it arrived in, covered in plastic & all. Below are the photos of it: And while the guys at Hypergear were making it in-shop, they sent me some photos of the process: I'm looking at selling this just because I'm in need of the money right now, and don't have plans on modifying the 34 anytime soon - and from reviews & peformance sheets, this turbo had amazing results back when I was researching. The turbo was purchased in 2018 for $1.9k, with the mods I got added on. Looking at the website now, for the same turbo they sell (ATR45SAT), with the current addons it adds up to $1830 for the turbo Current addons included: - Bolted dump adaptor - Ball bearing CHRA - Braided oil feeding line So I'm looking to possibly sell it for around $1800, with shipping included in that 1.8k, It cost me around $120 to ship - so yeah thought I'd throw it out there and see if anyone was interested in purchasing. Cheers!
