28 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Well, some of you have mentioned that you would like a dyno day run for SAU, I have been ringing around a few places to try and get prices.
Before going any further with the organising, I just need to know how many people would be interested in attending.
Obviously, the more people that come, the cheaper it will be and the more fun will be had.
So, if I could just call for members who are interested in an exclusive Dyno Day to say I, and I'll try and work out which option will be better financially from the few places that have responded with resonable prices.
Also, people's opinions on opening up the invite to another club if the numbers aren't reached to have an exclusive day. Please let us know your opinion on the matter, and who you might like to invite. (Eg. WRX club or something) It will be a CLUB that is invited.. Not a website (Eg. Boostcruising or Qld Streetcar).
So go nuts and tell me what you think of the ideas! Only putting down definites now. Maybe's dont help me make up numbers :)
List of people who have expressed interest
  • NismoGirl
  • Shane
  • predator (Gordon)
  • Lazy-Bastard (Warwick)
  • Jaqule (Beau)
  • JLNewton (Jason)
  • Nexus9 (Chris)
  • 33Niz (Matt)
  • strutto (Adrian)
  • belgarion (James)
  • ausgtr
  • TeamKrazy (Neil)
  • Melv
  • PTR33 (Peter)
  • Genesis (Glenn)
  • Platium (Luke)
  • dr30man
  • Knore
  • Wados (Wade)
  • darrinspencer
  • Spooks_Skyline (Dave)
  • Brett33
  • WHITE R32 (Jon)
  • owned (Nick)
  • summoner (Mark)
https://www.sau.com.au/forums/topic/45196-eoi-dyno-day/
  • Replies 78
not fussed whoever turns up if numbers are needed. Even the pope could turn up and we could test how much that beast the Pope Mobile puts out at the wheels, hell I'd be all for that too :(
Some idea on pricing may be good. Think a lot of the time what happens people go "I'm keen" then the price comes up and people go ohhh, maybe not. Then the numbers are less than expected. just my 2c
https://www.sau.com.au/forums/topic/45196-eoi-dyno-day/#findComment-921461
At the moment the prices I have are from Mercury Motorsport and The Brock Shop. With being a 4WD dyno, it's a little more expensive.
Mercury Motorsport - Newmarket (Also a sponsor of SAU QLD)
With around 30 cars the cost will be $45 per car. Obviously the less cars, the more it's going to cost. But that was an average of how many cars they will probably get through in a day of dyno'ing. That price is for both 2WD and 4WD which I thought was a good cost. That also includes like a "waiting room" which has like seating facilities, pool table, other "Stuff" and a screen which shows the dyno readout of the car that is being dynoed downstairs. It also includes a BBQ lunch for the the members running their cars on the dyno. Drinks are $1 each as well. Includes 2 power runs using the Shootout mode and a print out of the figure.
The Brock Shop - Underwood
They have said it would be around $40 for 2WD and $50 for 4WD with a dyno print out. Thats all the information I have obtained at this point in time. Not sure how many runs but I gather it would be 2 + a print out.
CNJ (Carb N Jet) - Underwood
$88 per car. I personally think this is WAY too expensive for a dyno run and a piece of paper.
Dynosource - Nerang
Still waiting for a response. I have been to Dynosource before and like the way they run the dyno days. Last time it cost $30 for 2WD and $40 for 4WD. That included two power runs using shoot out mode and a print out of the figure. Will wait to see what offer they have this time around. Apparently they have changed owners since then.
All the Dyno places I have contacted have been Dynonamics dynos because after the last SVD Dyno day, people didn't seem too happy with the power figures from the dynologics dyno.
https://www.sau.com.au/forums/topic/45196-eoi-dyno-day/#findComment-921586
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
