hi, i have looked all over this forum for an how to install thread to put the r34 gtt triple gauge pod into an r34 gt with no luck.
i was just seeing if anybody had done and could run it through with me step by step, or know of a thread with a step by step how to they could link me.
thank you
if you mean how does the pod that holds the guage install, remove the radio / ac surround, unclip the air vents, it unscrews from the front and unclips.
screw holes you can see at the front
oh thats right, they dont have the tv or anything, just a solid dash... yeah thats probably gonna make the job a bit shitter.
the thing to find out then is if the brackets are the same behind there to actually affix it to
owe yes some cutting would have to be involved I would assume.... and to remove the gauge pod you need only to wedge out the centre ac vents, then you will see 2 screws holding the pod in place (for GTT's anyway)
might be easier for you to look into mounting the gauges elsewhere?
I originally had everything set up like this >>>>>
But was too crowded so I actually installed my head unit where the gauges are supposed to go and put the gauges where the head unit was..
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
