trying to confirm some info i have been given, unsuccessfuly so i might as well just ask.
in later years i.e.94, did the R32 gtr adopt an early version on the R33 RB26?
if so, what were the main differences?
any other differences with late model 32gtrs?
if im spastic and missed some informative sticky post just redirect me.
cheers.
https://www.sau.com.au/forums/topic/451967-32-gtr-late-model-engine-change/
I suppose what you're asking is, "Did the late R32 26s get the better oil pump drive?", because that's really the only noticeable difference between the engines AFAIK.
And I may be wrong, but I thought that the change from skinny to full fat collar was in 1991.
Edited by GTSBoy
Correct from in 1992 they had a full drive collar.
Does not mean by any stretch of the imagination that the old oils pumps won't fail. I had a failure which dropped a bearing.
20+ year old super cars needs attention and love :)
The longer collar is built into the crank, not a actual collar added on, its part of the crank.
No it does not stop oil pumps from breaking.
Edit, just to add, it does reduce the chances of breaking a oil pump by speading the load and wear across a larger area, however oil pumps still break with the long nosed oil pump drive cranks.
Edited by GTRPSI
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
