My line had 149.8 RWKW totally stock! and its a 93 model with 84k on the clock,i now have 3" turbo back exhaust and hi-flow cat plus a k&n filter in the stock airbox but havent had it dynoed yet, this sounds very high when you guys are saying youve got similiar readings with the exhaust and pods?? would this be done to the difference in dynos or what?
  • 1 month later...
  • Replies 76
150 odd RWKW sounds about right if not a little high for a healthy stock motor on stock boost.
All dyno's are different though. If you want to see actual improvements keep going back to the same dyno.
  • 6 months later...
UPDATE: Power FC is in....
~200rwkW and 500Nm - 11psi... but problems...
At full throttle and 100% injector duty cycle the AFR only read 12.0 :P
Checked the fuel pressure and after a couple of hard runs it dropped from 40psi to 35psi
Fuel pump gone?
Any ideas anyone? I'm getting a new fuel pump and fuel pressure regulator installed next week, as that's what my mechanic/tuner suggested, then retune. Do you think that will fix the problem?
Forgot to mention the car drives like a fricken dream now. So smooth and power throughout the rev range. :cheers:
Your mech/tuner is on the money. should sort things out.
You may find the AFM is close to, if not out of resolution. This only becomes a problem if you want to turn boost down - the car will run rich.
To sort that out you will need a Z32 afm, but if you are happy driving it the way its tuned, dont bother until you start thinking about turning the wick up. Oh, and you may be due for a clutch before too long.
Welcome to the world of moddified cars :rofl:
Thanks guys :rofl:
steve, clutch was done a month ago with a 5kg flywheel so that's all sorted :D
hmm z32, I've still got the stock turbo, and only plan on going maybe 2540. Do you think I'd still need a z32 afm?
  • 1 year later...
hey all. read the whole thing. awesome results i must say.
what was the ambient temperature when the runs were done?? around 30 degrees celsius?
Also, how many k's has ur beast done man? :glare:
Likewise, great read - I'm in the process of looking for a reasonably stock R33 so I think I'll be heading down the same path as you. Have the cash to buy the car and do all of these mods in one go.
Worst part though, I had a malpassi RR reg and a Bosch 044 fuel pump on my cordia and I sold them only a few weeks ago!! :)
Thanks for the ideas :mad:
  • 1 month later...
apparently after i blew my new motor in my series 1 and put the series 2 motor in i made 159.7rwkw on 7psi was wondering if that seems a bit too high? air filter and exhausht thats it
  • 1 month later...
if you are just looking for a once-off upgrade for that little bit more power than some ECU tuning/aftermarket management would be a good option.
however...
once you are bitten by the modification bug you won't want to stop there :D
i agree with Zahos in that if you have a desired path that you wish to take with your modifications (ie exhaust/fmic/boost) that you seem to have expressed in your posts, then do all the 'bolt-on' mods first and than once its all finished get the management (ECU) organised. saves on tuning as you only have to get it done once rather than after each time you do a mod.
my order from stock skyline to mild beast would be:
- dump/front pipe
- high-flow panel filter + cold-air intake
- cat-back exhaust
- bleed valve (12psi on R32 or 10psi on R33)
- GTR camshafts (great cheap upgrade on rb20 but not sure of rb25)
- ECU retune / aftermarkt management
then if you decide that your pockets are real deep then the next set of upgrades aren't going to be cheap and the cost of a re-tune will be insignificant compared to the cost of the mod / fitting so can be justified...
good luck with it all
Waz.
ive done the same but added a fuel pump, and fmic, closely followed by a new clutch
Hi guys...great read...I'm a new guy to this whole scene...Im an ex-through and through holden fan who only ever worked on or knew holden engines...Ive since been influenced and converted...Im in the process of buying a Series II GTS25T. Im in the research and learn phase and just getting some ideas etc etc...just wanted to ask a quick question...you know how your all saying to get a good exhaust system...so like the front/dump pipe to the cat and finally the cat back...are you guys still using the stock intake manifold or extractors as I would call them? sorry if this is a newb question...if so what would be the gains of upgrading the exhaust from this point...so extractors--->front/dump--->Cat--->cat back...? I didnt notice anyone mentioning anything about brands or prices??? what is a good middle market fair priced system to go for thats going to make imporvements such as these...also with the front/dump pipe...just confirming that this is a dump pimp included in the front pipe and so a separate single stand alone dump pipe is not needed??? I also have seen a few performance INLET PLENUM what is the go with these? is this a bolt on mod? what is involved...? what are the gains and what makes a good from a bad one? btw are the stock turbos on a r33 high mount or low mount...? what is this anyway? im gathering its just where the turbo is located? sorry for all the crappy questions...any help is much appreciated...Cheers, Joe
well i dont know about everyone else here but my car made 215kw with a 2530 15psi stock manifold. the exhaust on it is 3inch off the turbo and the dump pipe is seperate to the front pipe on this system.
the standard manifold is low mount meaning the turbo is mounted low down on the car and high mounts are mounted up high belive it or not :(
  • 3 weeks later...
I'm in the same boat as you. You just have to look at the EJ wagon in my garage to see I can't let go. That said... there is a series 1 GTS4 sedan parked in the driveway now.
Extractors as you call them don't get changed much at this end. The stock units flow really quite well and only need changing when you change trubo configuration to a high mount or somthing with a bigger and different flange.
Intake manifolds are also pretty damn good, but what you connect to that is where you make the gains. The air comming into the turbo is important, so that is why pod filter in ducted cold air boxes are the go (or like me a much cheaper thought good foam panel filter - uni pro NOT hks). Then the turbo to the intak manifold is important with its intercooler to cool the intake air heated by the turbo (a trade off of the turbo running on super hot exhaust gas) and then all the piping.
The mods on here are where to start and just keep building up. When you out grow a mod you can easy sell it on here to the next person getting into it.
Stock turbos are low mount.
Hope that helps...
  • 6 months later...
This is an awesome topic, its really helping me out on my car. Like a lot of people who have posted here, im a new owner of an r33 gtst. Current mods are an apexi 3 inch cat back, Blitz fmic, and an unknown fuel pump (a new one was installed by the previous owner, i rang the guys who installed it, they told me it was a "petrojet" pump. To my knowledge, petrojet are a distributor of walbro pumps, but im not sure????)
My aim will be about 200rwkw at this stage. So far this is my plan of attack:
Splitfire Coilpacks
NGK sparkplugs
Hi flow cat
fuel pump + fuel reg
Apexi Power FC + Z32 AFM
550 cc injectors
tomei poncams
Am i on the right track here?? ive researched this a bit. What do you guys think?
  • 3 months later...
ok i dont know much about technicality..i have a 3 inch catback exhaust..i haven't checked under the car..just been told the exhaust is only catback...but if i was gonna get new and big front/dump pipe..wont i have to change the cat to a bigger one too? if not wont that restrict gas that i could let go? thanks
in a word, yes
My r33 made just over 180rwkw-->cat back, intake, 10psi. Yours if fine...mine is a little high :sweat:
Splitfire Coilpacks
NGK sparkplugs
Hi flow cat
550 cc injectors
tomei poncams
For that power scrap the list, all you need is the cat, power fc (or a retune/piggyback) boosted to 12-13psi MAX and make sure your intake and exhaust are free-flowing (3inch). Give the car some good oil and plugs (i use Motul Turbolight 4100, NGK copper gapped to 0.8mm). The other mods are only needed for higher power, and the turbo will need replacing in that case. Realistically the car will make close to 200rwkw (depending on condition, i.e fuel pump might be tired). i'd just be concerned if the turbo will reach that power. Good luck :teehee:
Edited by R338OY
