Hello all,
Have some parts taking up space in my garage that I want to get rid of.
Location - Brisbane (5 kms South of CBD) - Local pickup only for now.
Email: david.madds@gmail
Phone: Zero Four Two Zero 208 177
1. HKS Height and damper adjustable coilovers - $450 (BRISBANE ONLY - may consider posting if I cant move them - will be pretty exy I imagine)
Spring rates are F8 and R6 with a helper spring on the rears.
Not sure of age or km's as they came with the car from Japan.
Have done a 1:49 on street rubber at Phillip Island with these coilovers.
No leaks and still in work great - Have changed to Shockworks
2. Apex intake pipe - $50
Was on my car from japan - suits stock turbo or any turbo with the same compressor intake size and bolt patern. Has been used on HKS25/35 and GTRS with no problems.
3. Also have a set of GKtech front lower arms (Standard R33 GTST Length) that have been ground to fit GTST - $200
There is a story to go with these so let me know if you are interested. Will fit S chassis also. Only ever trial fit.
Cheers,
Dave
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
