Hello so I've brought a R33 Gtst. My first ever turbo car. Im looking to get it around 350 HP at the wheels. Now I've been doing a bit of research and I think I've found a good list of parts I need to make this possible. Just want to see what you guys think before I blow all my money. (Car at the moment is bog stock. Car is also automatic. I kind of want it for drags and circuit. I know manual is better but my daily is manual I wanted something different)
Parts:
-Intercooler
-Turbo smart boost tee & Boost guage
-Nismo 555cc injectors
-Turbo gt3037 (do I need better?)
-Apexi power intake
-Walbro 255 L/PH fuel pump
-Low mount & dump pipe
-R33 S2 AFM (Or Z32?)
-Lightweight pully kit
-And a tune (what's best tune to get).
This car is a track car so not ever going to be road legal so dont mind if I have to straight pipe or what ever.
Would that be enough to make 350 HP at the wheels? Or would I need a few more upgrades. Money isnt too much of an issue but would rather keep it below 2-3k.
Cheers guys
https://www.sau.com.au/forums/topic/452592-r33-350-hp-build-need-help/
if you feel like saving money then just get a hypergear highflow done to your turbo.Those injectors and 18psi on petrol will make 350rw ponies easy.
Adaptronic ecu is much better than a nistune + Z32 afm
  • Like 1
Although 3k might be a little optimistic as around 2k for ecu and turbo, then it needs tune for around 60-1000 depending on where you go, then there's still a fmic kit and exhaust
Guess I'll be spending more money then haha
hyper gear high flow 850.
full 3 inch exhaust and dump, 2-400 drift sales.
injectors and fuel rail, again bargains to be had second hand, 2-800
tune 750
emanage blue 200 dollars or power fc 6-900
fuel pump 100 bucks.
e85.
will make your power figure easily.
  • Like 1
Have you played with the cam timing on the 32 ?
I see in your sig your 33 has a fair few bolt ons, what does the 32 have ?
I guess its your 32 that has 271kw ( if written respectively) plus the 32 GTR is 40kg heavier then the 33 GTS-t and there's fark all difference :/ , try getting the LCAs of the 32 cams to 110-108deg and see if there is still fark all difference :D
or try taking your motor thats been dialed in, and doing power runs at a further 20 degree intake retard, or a 20 degree advance, and see if there are any areas where you can from the extra advance, this will show you the use for vct
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
