Hey there, I've currently got 3 leaking fuel injectors and looking to replace them, one is leaking pretty bad will that cause the car to run lean? I'm unsure of what to do, do i go standard injectors, or do i go bigger, I've heard you need a power fc for some injectors and i am planning on running one in the future. Car is a 1994 r32 gtr
Edited by booba32
https://www.sau.com.au/forums/topic/452676-leaking-fuel-injectors/
If it's leaking out the bottom into the manifold it will run richer, if leakong out the top and over the motor it will run leaning and start a fire. If you change to anything besides stock you will need some sort of aftermarket ecu management, be that a nistune,power fc, adaptronic or any other ecu. The car will not run right without doing that. So if you change to bigger injectors you need a new ecu now. Yet what are you looking to get out of the car first, as if your happy stock, or even up 300awkw the stock injectors are up to the task, if you want to go heaps more power or e85 then yes injectors are needed.
The way I would do it right now, to avoid a fire, is replace all 6 with some better injectors, install Nistune, get the K factor tweaked on the dyno for a very small charge and walk away happy knowing that I've only spent the money once, not setting myself up to spend it twice.
If you can't afford to cough up $2 or $3k every time your car decides to show its age, then you can't afford to own a GTR. Spend the money when it's needed, and you will be fine.
RB26 injectors? Probably just the Oring leaking at the rail. I can post you some new ones in a letter for bugger all if you want to change them yourself...
Clean them up so you can see anything leaking after the Orings are done.
Well, if per what others above have said it is just o-rings that need replacing, then paying for "reconditioning" could lead you to spend far more money on those injectors than is warranted. Just buying o-rings for them may be all that is needed.
If you plan to use your PFC to push the power higher than stock injectors can go, then spending ANY money on them would be wasted. Spending it on new, better injectors would be far smarter.
Stock 26 injectors were good for about 400HP at the engine. So that's about 300 HP at wheels, 225rwkW.
Maybe as much as 50 engine HP more than that depending on fuel pressure, choice of dyno, a few other factors.I
In other words, they are big enough for what you're wanting. But what you're asking for is actually pretty much how much power a GTR made when you simply remove the boost restrictor anyway. ie, stock power as Nissan intended it.
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
