I am going to need new shoes for my R34 GTT,
It comes with Stock R32 GTR RIMS,
Does the 245 in 245/50R16 mean the width of a tyre in mm?
Can I use a tire as large as 245 width? or will it look bad / wont fit? I want a solid parallel fit no angle due to too large/ too small tire.
Whats a common tire size people buy? 225? 235?
Thanks
To answer your question - yes to width of tyre size for 245
Stock r32 gtr - 16x8 +30 wheel, Tyre 225/50R16
I'm not sure why you want them on your 34GTT. 18's look so much better.
Can you use 245's on the 32 GTR rims - yes.
I've not tried the combination of R32 GTR rims on a 34GTT so not sure on flush fit but I can say they will look small and gappy around the circumference.
245s will look horrible on an 8" rim. Quite baggy. 225 is correct and works well at 50 profile. 235 is a little too tall at 50 profile (longer gearing) and a fair bit too short (shorter gearing) at 45 profile. 245 will be a lot too tall at 50 profile. not as bad in 45, but still not quite right - as well as being baggy anyway.
Tyre manufacturers rate this size for use between 7 - 8.5 in wide tyres, perfectly in spec... although stretch/stance-fairies may dislike it.
Variance in speed is only +3%, about the same as most people get jumping to common 18" wheel sizes
245/50/R16s on my GTR a few years ago.
^ That picture reminds me of all the HQ Kingers I grew up with with 265 tyres on Dragways bulging out all over the place. Cool in the 80s. Things have changed. The only reason you get away with it in that photo is because we're talking tyres with tall enough sidewalls to take the abuse. You wouldn't get it to work with a 35 profile tyre.
I think there's a big difference between "stretch/stance fairies" and those of us who see baggy sidewalls like that as being incorrect fitment. The 245 tyre will probably provide worse handling and grip than the correct 225 size just from the sidewalls being mechanically bent out of shape, regardless of the extra rubber on the road.
Don't get me wrong, I've done it too. I ran 225/50 on 6.5" GTSt rims, which is about the same level of wrongness. It was OK, but it wasn't great.
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
