Sau:nsw - Monthly Meet February - Sunday Morning Cruise & Breakfast
Noise defect as in epa? If so that sucks so much dick. I hate them, normal defects in don't mind, they make me money. Yet epa defects are so crap as they idiots at the testing facilities don't know what there on about and aren't trained correctly. Had to ask a customer of mine where the egr valve is installed on the exhaust manifold in his cobra was......
Annnnnnnnnnd I can't make this event now =( got a family/church event that I'm not allowed to miss... Sorry guys & girls!! And I was really looking forward to it =(
tell your family you're on a pilgrimage to see God's beautiful creation known as the RNP ;););)
I'm sure they will understand
  • Like 1
Okay so Austi Beach have finally got back to me with their set menu. The idea behind this is it will be easier to bill as everyone will be seated at one big table. They have amended the menu to include the Big Breakfast which Im sure is going to be the top pick.
If there is any issues, do let me know.
Thanks.
Breakfast Group February 2015 (1).doc
  • Like 1
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
