Hey Guys,
Currently I have the NITTO INVO 235 40 18 fitted to the Axis Autech factory rims. It's nearing time to replace the tyres and I am looking at going Kumho 245 50 18 on the Axis rims.
Basically the current tyre profile simply makes the wheels look like skateboard wheels, they just don't fill the guards enough and look out of place.
It appears I have plenty of space to play with to accommodate 245 50 size tires.
Wondering what people are running, especially on their M35 Axis rims.
Also recommendations of very highly reputable places to have them fitted, balanced and wheel alignment done. No $hit in the past I've had tyre place leave the wheel nuts hand tightened only, not once, not twice but yes 3 times and across all 4 wheels.
https://www.sau.com.au/forums/topic/453503-tyres-for-my-m35-axis-autech/
245/45/18 is a much better size than the 50 profile you're looking at. The 50 profile will have miles too much sidewall.
As a bonus; it is standard size for VE/VF Commodores, so prices a sensible, and they're easy to get.
It reduces the speedo error from around 9-10% to around 3%, which is also useful.
I'm running 245/45/18 Khumo KU31's and have done for years. They are quiet, wear well, and have good grip; wet and dry.
Any recommendations where to score some KU31's at a good price?
The best advice I can give here is ring around everywhere (or at least everywhere you think you can trust, given the previous problems you've had), and specify the exact size, speed rating and weight details you require.
I'd also recommend Michelin Pilot Sport 3 tyres (if they're within your budget), I have them on my C34 and they're great!
I buy them through a local tyre place, and they will match the Imported price on Australian stock. Which ends up about $200 per tyre fitted/balanced.
I've had both import and Australian delivered; I couldn't tell the difference.
Plenty of places on fleabay will freight them, but do the ring around; most of the time you can find them fitted/balanced locally for within a few dollars of freighting, then trying to get a shop to fit them for you.
The only thing I'd criticise is the asymmetric nature of the MOMO tyre as compared to the KU31.
I tend to get an amount of camber wear on the inside edges of my tyres, and with the KU31's; I can have them flipped on the rims to get more wear from them.
Other than that, they seem to be a good thing.
http://www.sau.com.au/forums/topic/434880-momo-outrun-m3-tyres-has-anyone-tried-these/
Hello,
I had the Toyo Proxes 4 on my AXIS, they were fantastic and importantly had the right load rating, you will find that the AXIS is 630kg where as other mainstream is a bit lower. . 245/40ZR18 97W & 245/45ZR18 100W, if I recall didn't alter the rolling stock diameter too much. .
My 2 cents worth is Toyo Proxes 4 hands down. .
Jules
They go ok Jules.
They're a 300 treadwear; I reckon I get better than 30,000km per set of 4.
I swap them front to rear every 10k and when the inner edges start to wear; I flip them on the rims.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
