  • Replies 62
Originally posted by BY BY
Might be interested,
Silly question porgie, what frequency do you need to tune ur stereo to? Ive never been and my system is yet to be chipped to go over 90mhz
theres speakers too... my 'line hadn't been chipped when i last went either.
Christian
BASS HILL
BAD COMPANY [M] 116 Mins
Fri 11 Oct 7:30pm
BEND IT LIKE BECKHAM [PG] 112 Mins
Fri 11 Oct 7:30pm
REIGN OF FIRE [M] 102 Mins
Fri 11 Oct 9:45pm
SWIMFAN [M] 85 Mins
Fri 11 Oct 9:45pm
BLACTOWN
Fri 11 Oct 7:30pm
Fri 11 Oct 7:30pm
Fri 11 Oct 9:45pm
SWIMFAN [M] 85 Mins
Fri 11 Oct 9:45pm
Well I would have done Bass Hill,,,I would have thought it closer for everybody,,,,Oh well,,,,Porg coming from south-west(beach Area) and the Northaners.....Stick Blacktown,,,,Bass Hill kills it....
Swimfan looks interesting........
Neil
Carlo,
Depends where we are going & what time. - if it's Blacktown & 7:30, I'll go straight there cause I work close. If it's Bass Hill & later, then yeah - I'll meet up with yas.
Someone (Onarun, your call mate) make a decision - I dont' care which now !!
i don't really care either
...but for the sake of making a decision
meet at homebush at 8:30 sharp
leaving at 8:50 sharp
going down the M4 going to blactown drive-in to watch the 9:45 session of reign of fire
cost is $12
if you are running late call me (George) on 0438 438 567 or get your arse down to the drive-in and look for all the skylines
aiight
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
