Any tips on preventing turbo -> dump pipe studs or any other stud subjected to heat from snapping?
It seems no matter what I try I always have at least one stud either snapping or threading in it's bore.
•I always use genuine Nissan studs (inconel?)
•I always torque them to spec
•I generally chase the threads to make sure they're clean before installing hardware
•Tried using nickel anti-seize but it seems to gum up the threads making installation difficult
Any way to stop this, as I take my turbo off pretty often and it's annoying having to extract studs and helcoil each time.
https://www.sau.com.au/forums/topic/453759-prevent-exhaust-studs-from-snapping/
The amount of heat these bolts have to tolerate is huge,no way will they last forever its impossible, hot and cold,and then they crack and brake had to get mine replaced several times over the last 12 years.Do I still love my 93 skyline ? you bet I do bang for buck and if you look after them they are fantastic nothing better. :-) :-) :-) :-) :-) :-) :-) :-)
I would say the flange isn't straight, or the exhaust is causing it. Do you have a flex join in the front pipe?
Never heard of the dump studs/bolts snapping. Anti seize should be helping, but perhaps the nuts are crap too? They shouldn't be too tight or they will gall up and bind, especially if warm still.
Unfortunately the Skyline hangers are pretty crappy, there is nothing to stop the muffler moving side to side when you corner. This force is transferred down into the turbo/manifold, and the exhaust makes for a very long and heavy breaker bar. I always put a flex into the front pipe for this reason.
  • Like 1
Had this problem when I took my stock turbo out but I assume mine was just from old age as the bolts where the factory ones from 16 years ago. Do you have a link to where you are buying the nissan ones from as I need a set?
I was going to make a thread about this a while back. If you look up "landcruiser exhaust mount" you should find these rubber bushes with bolts attached like so:
http://www.ebay.com.au/itm/Landcruiser-HZJ80-HDJ80-Series-Exhaust-Mount-Rubber-Set-3-/201205416170?pt=LH_DefaultDomain_15&hash=item2ed8c700ea
I have replaced my rear exhaust hangers, and the cat converter brace with custom brackets and these rubber mounts. The rubber has flex in order to absorb vibration and allow for expansion of metal, but the exhaust cant sway in any direction very far. I find even hard hangers dont work because even if they dont stretch, the pendulum effect allows the exhaust to swing and touch things.
  • Like 1
Interesting stuff and perhaps a really stupid statement or question but I knew my studs were broken and a couple were but it didn't affect how the vehicle ran. I suppose my question is if I have a permanent street setup will I have to routinely remove these studs every year or two years?
Edited by Therealsandybang
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
    • I ordered a GSP Front R/H Axle from here - https://justjap.com/products/gsp-premium-front-driveshaft-r-h-nissan-r32-r33-r34-skyline-gtr-stagea-4wd#description It lasted around a year before one of the boots blew out. I'm lowered, but I have GKTech roll center adjusters. One year seems a little premature. I think I'm going to spend the extra money on an OEM cv axle this time. This website - https://tfaspeed.com/collections/nissan-stagea-wgnc34-x-four-parts/products/nissan-stagea-awc34-260rs-rb26-right-front-axle-drive-assembly Makes it sound like the readily available OEM CV axle will only fit 11.1999 Stagea and up (mine is a 2.1997 S1). The JustJap listing didn't mention any years or anything for the GSP axle. Amayama shows '11.1999' and up as well for that part number. As well as 'plastic boot type'. See attached picture. So I guess my question is, does that axle (39100-23U60) really only fit S2 Stagea? It's the front driver side. If it does, I'd love to buy that instead of rolling the dice on another GSP. I've found that OEM one cheaper here: https://www.partsfornissans.com/oem-parts/nismo-jdm-r32-r33-r34-skyline-gtr-r32-gts4-right-front-axle-3910023u60 and here https://www.nissanparts.cc/oem-parts/nismo-shaft-ft-drive-3910023u60 Just a little confused because the JapSpeed listing for the GSP front driver axle doesn't mention any specific years or anything and it fit my S1 Stagea fine. So will 39100-23U60 fit my S1 Stagea even though technically it says '11.1999' and up? What would have changed? Thanks.
    • Thanks for the info. The only "Issue" I've had with the shifter is I always found the throw between 4th and 6th gear too close. I'm always worried to shift into 4th accidently and sending my motor to the moon. Adam LZ recently came out with a video and stated Serialnine revised their shifters to correct this and will change all the revised parts for 150$. Strangely enough, I contacted Serialnine right after and they denied it and said it's bullshit. I found that strange as he's a distributer. I'll keep this forum post updated on that saga.
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
