No limit to budget, but was going to buy a ebay manifold...????
Sounds like you dont really have a clue about what is involved in "your dreams"...
Sorry, i know you dont want to hear negs, but really your about to waste alot of time and money and end up with very little, i fear
it looked good to me,
he claims a life time warranty (which may or may not be 100% true its ebay after all)
i was asking for advice, not to get told that i dont know anything
boys, be human for a second, if i thought that i knew everything, why would i come online and ask questions
im happy to hear of better ways to do things, that way i will build a better car,
btw, this idea has progressed into a new project, i have decided to throw a VR38 into the r32
i started a new thread,
If you look hard enough for Ebay manifold Reviews you will find a thread about some Madzaspeed 3 guys who are using manifolds that look JUST like this that are made by XS-power. They are the GEN 3 manifolds from XS-power and the thread has guys who have been testing the XS-power gen1-3 manifolds. It's strange that this one seems to be made by this TOG shop and looks JUST like the geometry of the XS-power RB26dett T4 divided manifold, but is welded steam pipe. This is what XS-power has done with their gen3 Mazdaspeed manifold.
Another note (not that I'm trying so hard to justify "china" manifolds), but Aaron with Driftmotion.com over here in the states has been using China manifolds for YEARS on his budget Supra turbo kits. He offers REAL Garrett turbos, but he has said that some of the China manifold brands have had some amazingly reliable results on their cars. He likes the wastegates, BOV's, and Manifolds and says he doesn't stock anything that doesn't work. He did say some of them are clearly junk, while other brands are tried and true. He did steer me to some specific brands to look for since he doesn't sell manifolds for RB engines yet and wanted me to send him specific pictures of what I find. Guinea pig!
Either way I hope it drives The Full-Race or other similar brands pricing back down into reality. It sure is hard to justify spend more on a "dumb iron" piece of pipe than the actual turbo (which has decades of engineering research, and moving parts!).
Found it. Post number 654
http://www.mazdaspeedforums.org/forum/f10/xs-power-turbo-manifold-here-install-pics-154973/index17.html#post2767493
Edited by HarrisRacing
your too right mate
im my line of work we design and manufacture products
once the hard work has been done and all the plans are made,
it is easy to copy it, you can make a good copy or a crappy copy
you can get some indication from the quality by the reputation of the re seller and the support they promise
a reputable re seller will not stock garbage (you would hope)
and in my head, whats the worst that could happen, it will crack,
its not like its gonna explode and kill me and everyone in the car
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
