R34/C34 Series 2 RB25DET Neo Apexi PowerFC with hand controller - $1100
R34/C34 Series 2 RB25DET Neo Splitfire Coilpacks - $450
R33/C34 Series 1 RB25DET Series 1 Splitfire Coilpacks - $400
R32 GT-R HKS Adjustable Coilover suspension - $800
R34 GT-T GT-R Xenon Headlights - $950
R33 RB25DET Engine, complete with loom - $1600
R34 RB25DE Neo engine - $500
RB25DET NEO engine, complete good running - $2500
Various diffs (PM ratio, ABS etc. with what you want) - $250-350
Need these moved ASAP. Can post interstate. Pick up Villawood area.
Hi Nick
What's the part number for the splitfires? SF-DIS-001?
Are they new?
Cheers
parts are used but in good condition. exact part number is unknown, not printed on the coilpack itself. took these out of a RB25DET Neo.
Hi Nick
Are they new?
Cheers
  • 5 months later...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
