So I was browsing the part diagrams for the R32 and found parts listed for fender mounted side mirrors and blank covers for the door mounted mirrors. Me being the loser that I am, I wanted to see what my GTR looked like with the passenger mirror deleted (most of the old muscle cars had only drivers mirrors in the 60s) since the delete plate is pretty cheap. That got me thinking though, Ive never seen the fender mounted side mirrors on any R32, couldn't even find a picture on google images for it. Anyone ever seen these installed or have a picture of them?
https://www.sau.com.au/forums/topic/454292-r32-fender-mounted-side-mirrors/
Update, got the blank installed along with some new trim and small pieces for the doors today and this is what she looks like...
75292F90-57B5-4977-B85D-ECB4CCEC2F2A_zps
5064B77E-6DC3-4717-A4BC-97C17656C131_zps
I really like the sleek look but I think the large drivers mirror throws it off. Im not really convinced of the look yet but I was thinking either a low profile fender mirror might be able to pull it off or I could try for a low profile drivers mirror in black to even out the color. In the mean time it will keep my interior dry while I fix my mirror motors.
Thoughts?
Don't even think about fender mirrors. You will have a tiny field of vision from them. There's a reason they don't put them there anymore! As for deleting the passenger side mirror - words fail me!
If you really hate them so much get some Ganador mrrors.
If I hated the standard side mirrors then I wouldn't be taking the time to fix the motors in them, as stated in the post above I am using the blank to keep water out of the car while I do this.
As for the side mirrors there are many cars in japan that continue to use them, mostly Toyota. Although you lose some vision due to mirrors being an increased distance away from the driver you gain a better view of both mirrors by moving them inward and forward allowing easier viewing (read less head movement to check your mirrors).
This was simply an idea I had that serves a purpose while giving a fresh perspective on a way to set up an R32 that would be very different than just throwing on a ganador miror.
Bumper mounted mirrors it is!
Nizmo, I agree, I don't think there is going to be a mirror that will look like it belongs or is not awful.
Those rain guards are nissan oem, I'll get you a part number if you want it.
I would be keen to know the part number. If you could post it that would be great.
Jase
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
