Check your CAS mate, mine was busted with very similar symptoms: http://www.sau.com.au/forums/topic/326043-resolved-misfire-in-r34-gtt-rb25det-neo/
Edited by V28VX37
It started happening lastnight it did it twice and then when i drove it this morning it was happening slightly again but after driving for 10 minutes it started completely dying its normally around take off, at one point i was at the lights and i reves the engine up slowly and when it hit around 2.2k revs it started to shutter then when i took of from the lights slowly 5 metres up it started shuttering bad its feels like when you tap the accelerator hard, i had to pull over because the accelarator was keeping it at 1.5-2k revs and not going any higher i turned the car on and off tryed reving it a few more times it finally worked got 15 metres around the corner it started jerking and doing the same thing and the engine light came on i pulled over turned it off tryed to look for a problem turned it back on and it reved up fine and i made it home from there which is a 5 minute drive but it was slugging and shuttering most the way
Just my two cents but I had a afm issue not long ago and ended up having to replace it, it's a very fragile part and even by cleaning it they can be damaged. If it is your afm I suggest replacing it with one that definitely works 100%. A slight bump can kill them so be careful
it was doin it a bit the night before and i cleaned the afm the next day before i went on the short drive, 10 minutes later it was still bad then just got alot worse,ill look into getting a new afm see if that helps at all, i saw similar problems last night where it was coil packs, could it be my coil packs aswell ? Thanks for the help guys i really apreciate it
Just a quick update guys went to start car this morning kept wanting to die and would not at all go past 2k revs i pop the bonnet try bush the afm cord in and it dies, so i took the cord out and put it back into the connection now she will rev normal, so definately has to be afm
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
