Hey guys,
Coming to sydney in a few weeks for a fri sat and sunday before i go overseas.
Im staying in the heart of circular quays.
What is the night life fri n sat nights like there?
Where would you recommend?
any help would be great
cheers
If you're staying in Circular Quay the closest area with a decent night life would probably be the Rocks but that is mainly pubs and restaurants. Wandering a bit further to darling harbour will get you to cargo bar/king st wharf and a bit younger crowd.
Kings Cross is a lot quieter than it used to be since the lock-out laws came in but there are still plenty of places open.
Thanks mate.... ill google the cargo bar.... yer looking for a bit younger crowd...
but after a decent bar / music with a younger crowd nothing major
Edited by Adz2332
If you're staying in circular key be careful of the lockout, all pubs and clubs won't let you in the door after 1:30am in certain areas of kings cross and CBD. I'd google it and you should get the picture with the lockout zones in it. If not give me a shout and I'll try and find it.
There's an awesome German bar/restaurant called Lowenbrau in the rocks which is 2 minutes from circular quay, it's great for a big lunch feed and some quality steins.
If you're into craft beers try a place called Harts, they brew their own beer and use some other local breweries and they're amazing beers.
As far as clubs and what not I'd try places like Bar 100, again in the rocks but is more night club like
Hope some of that helps :)
hahah fair point....
For one would like a nice var, younger crowd not over in the 40s etc...
Then not so much a night club but a bar with music again young crowd preferred....
Ive been to darling harbour once before, and all i can remember of it was 50 somethings in very bar i went to
the glenmores a good place to visit on a friday if you get in later arvo, although can get crowded with the afterwork crowd.
Can also venture on to the Argyle from there afterwards. Was my old friday night special when I used to work around there
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
