I'm currently running a HKS kevlar timing belt for my RB26; I started asking around and I'm getting quite poor feedback from non OEM belts. The engine I am running is fairly powerful and I was under the impression that the kevlar belts were required for making big numbers.
I'm looking at replacing this belt now and I was thinking about using a tomei kevlar belt but now I'm thinking maybe just go OEM or gates, even though I'm running a lot more than a standard skyline.
Thanks!
https://www.sau.com.au/forums/topic/454408-non-oem-timing-belts/
Mentioned quite a few time that you are running more power but havent given a figure. Will make a difference what people will recommend if your running 1000hp or 500hp
I run Gates, im running 'alot' more power than a standard 25 but its only around 300rwkw
No problem with my belt
Well, with power comes the extra stress from non standard cams and valves
I've always gone for the kevlar belts but it's just whether or not I'm doing more harm than good by adding additional wear on the water pump and tensioners.
I believe that the OEM belts have very little vibration whereas the kevlar belts tend to be more rigid which puts additional stress on the pump.
I'd be inclined to suggest that there is a correlation between a vehicle with higher power figures and uprated cams/springs. I certainly have none-standard parts on the vehicle in question which are part of the package for increasing the amount of power that it can produce.
I'm not an expert at this and if you're trying to prove me incorrect then I'm more inclined to accept this and listen to what you have to say; if you have anything constructive, that is?
What I have said is constructive.
Making more power doesn't mean the timing belt needs to be upgraded.
Running more aggressive cans and springs might mean the belt is under more load, but realistically with a 100,000k service interval on a stock engine, if you used an oem belt and replaced it every 50,000 that would surely be ample.
The timing belt doesn't touch the water pump, so don't worry about that.
Perhaps you are confused as the pump typically gets replaced when the timing belt is done, thats only because the belt has to be removed to take the water pump off so it makes sense to do it then (just like cam and crank seals)
Not necessarily. If everything us working happily I'd leave it as is.
The scatter issue causes trouble when tuning, with the car pinging when it probably shouldn't etc.
The power fc doesn't seem yo be badly affected anyway, as it is an older and slower ecu which doesn't see the scatter like newer faster ecus do.
Well, unfortunately, upon inspection at the weekend, I found a small, almost incision like, cut on the kevlar belt; it's only a 1mm nick that doesn't even go deep past the surface but it's enough to bother me. It's probably been there since the belt went on, in all honesty, as it doesn't look like a wear and tear rip.
Probably just going to go with just replacing the belt with an OEM one as the HKS belt hasn't been on long, maybe 10,000km so no need to replace the tensioners, unless anyone thinks otherwise?
Have put on 7-8 gates timing belts and never had them whine. My mate (qualified mechanic) put his HKS belt on and it whines. I'm going to assume it's all to do with how much you tension them to rather than the gates belt itself tbh.
There has been some extra timing scatter found when using Kevlar belts with high ramp rate cams with heavy springs.
So far much of it, including the noise produced has been thought to be the belt tooth design when meshing with the gears, current thinking of many engine builders belive this aggravates/adds to the scatter issue.
OEM has been found to be the least effected, or the most forgiving, or the best at absorbing the harmonics.
With force on the belts and the harmonics produced, its based on how much lift and how agressive the ramp rate (both opening and closing the valves) of the cam lobes is combined with high spring loads working against the lobes, these harmonics are transfered to the cam gears and on to the belt.
Enough spring force and crazy cam ramp rates can even twist cams on some engines (more so pushrod engines), in these cases billet cams that have the lobes joined are used to add strength to tie the lobes into phase from front to back.
Low gentle lift with softish springs should produce little force onto the cam belt.
  • Like 1
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
