Hey Guys thought id Combine a few of my adds for easy bumping/access...
Going through a RB26 build, using this to fund it. I may swap some of these parts for some parts for my build. Please enquire.
Cheers (sorry for lack of photos will upload more.)
0403485395
Factory RB26 Twin turbo Set up (can be seen running + boosting)
Altogether $1800 FIRM (will swap for high mount twin set up, or forged pistons + Rods)
- 200KM old after Rebuild Trust T517z 8cm turbos 420kw turbos + actuators $1500
- Standard Manifolds $100
- R33 GTR Dumps (bungs for R32 o2 sensor or r33) $70
- All fittings and braided lines $100
- All piping (twin turbo pipe etc) $100
- Heatshields $50
- Trust Front pipes $150
RB26 Sump + Diff
Has a chip on the corner. Seems in good nick.
$100
RB26 stock rods + Pistons
Pistons A1 Nick, 2 Rods spun a bearing
$50
RB26 OEM TURBO STEEL WATER + OIL LINES
$50
Genuine Plastic R32 GTR Front Bar + Lip
Resprayed + fibre glass repair, in decent nick
$250 FIRM
<a href="http://tinypic.com?ref=2mzw0ih" target="_blank"><img src="http://i59.tinypic.com/2mzw0ih.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
R32 SHORT NOSE CRANK
Spun 2 rod bearings
$200
RB26 Factory 444cc Injectors
- Out of a V spec, have been cleaned
$100
May add some more bits i may of forgotten.
Edited by Cateans05
https://www.sau.com.au/forums/topic/454664-gtr-parts-clear-out/
  • 6 months later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
