Installing New Seats
DIY on installing replica SRIII Recaro Seats on Skyline 350GT Coupe (CPV35)
post-133804-0-65516700-1426125389_thumb.jpg post-133804-0-96192700-1426125418_thumb.jpg
Tools Needed:
  • 14mm socket wrench
  • Flat heat screw driver
  • Plier (Needle nose)
  • Set of Allen Key (Optional)
  • 0.5W or 1W 2R2 2.2 Ohm (NOT 2.2 k Ohm) Resistor (RED RED GOLD GOLD) to cancel the airbag light on dash (A pair can be bought from Jaycar for 45 cents)
  • Wiring tape (Nitto tape)
  • Scissors
  • Cable ties (Optional)
  • Hacksaw or metal cutting circular saw (Very very very optional)
  • A few M10 x 1.25 (length depends on your seat rails) bolts and washers (Optional)
  • A friend (Optional)
  • Google (Optional)
Stock Seats Weight (Including Rails etc.):
  • Drivers Side 26.75Kg
  • Passenger Side 23.45Kg
post-133804-0-34837400-1426124959_thumb.jpg post-133804-0-72757900-1426125104_thumb.jpg
Recaro Replica Seats Weight (Including Rails etc.):
  • Drivers Side 18.30Kg
  • Passenger Side 17.90Kg
1. Removing the stock seats (If you know what you are doing, it takes no more than 10 minutes):
  1. Remove the rail/screw covers by pulling them up. The rail cover for the rear bolts needs to be pressed in the centre and then slide it out. Shaking it a bit might help remove them.
post-133804-0-22307800-1426124983_thumb.jpg post-133804-0-18930600-1426125005_thumb.jpg
post-133804-0-61276500-1426125030_thumb.jpg post-133804-0-10574700-1426125049_thumb.jpg
2. Use a 14mm socket and remove all 4 bolts.
3. Tilt the seat back to remove the harness under it.
4. Carefully remove the seat. For the driver side, moving up the steering wheel will give you more room to remove the seat. This can be done by yourself but having a friend will help. Folding the seat will also help removing it but luckily the coupe’s door is large so there will be no problem. The passenger seat is much easier to remove.
5. Remove the seat belt socket.
Good vacuum clean inside as you can reach places where you cannot when the seat is there. You may also find some money! I found around $3 in coins lol
post-133804-0-55210300-1426125128_thumb.jpg post-133804-0-67341300-1426125086_thumb.jpg
2. Making SRS airbag canceller (do this before installing the new seats!)
When you unplug all the wiring harness for the stock seats, you will have the SRS airbag error light flashing on your dash board. This is because you unplugged the airbag sensor. You may need to do step no. 4 even if your new seats have airbags. If they don’t then follow the following instructions:
Resistor Package
  1. Using a plier, bend both ends of the resistor so it becomes thicker
  2. Insert (the side does not matter) it into the airbag wiring
  3. Make sure it is firmly in place and touching the terminals inside of it
4. Run the airbag diagnostics/resetting. To reset the light simply turn the ignition to the on position, (you don’t need to start it). All the lights should stay on for their diagnostic check. As soon as the airbag light goes off, before it starts flashing, immediately turn the car off. Repeat this 3 or 4 times (turning to on then off) and the light should go away.
5. Wrap the resistor with wiring tape
6. You may want to organise the wires under the seats with some cable ties
3. Installing New Seats:
This will vary depending on what kind of seat and rails you get, but most of the part should be fairly similar. I got my seats from China (brought them with me as check-in luggage on the airplane lol). I had to dissemble the back part and seat part so I could pack it within accepted luggage size. The main problem that you may have is with the seat rails… The seller in China did not have the rails for the CPV35, so I got for the 350Z as the measurements are the same. However, I needed to do some modifications to use these rails. I had to cut the rails “cross bars” as there are a small “bump” on the floor on both sides. Took 4 hours to cut them using a hacksaw (wish I had a circular saw lol).
  1. Flip the seats and install the seat brackets that move back and forth. You will need to press the place I circulated and move it back and forth to put the screws. For mine I used a 6mm Allen Key.
post-133804-0-96165300-1426125301_thumb.jpg post-133804-0-84326400-1426125324_thumb.jpg
2. Install the seat rails (if you purchased one specifically for the CPV35, then you may not need modification).
post-133804-0-78080800-1426125343_thumb.jpg post-133804-0-93678200-1426125356_thumb.jpg
3. Install the seat belt socket on the side of the seat rail. You may need a new bolt and washer to secure it in place.
4. Put the seat into position and tighten the bolts (stock bolts).
post-133804-0-59425400-1426125796_thumb.jpg post-133804-0-22372000-1426125812_thumb.jpg
PS.: You will note that the driver side floor for the rails is not even. The left side is higher than the right. What I did was to buy a longer bolt and a few washers/bolt spacers to fill the gap on the right side as my rails were for the 350Z. The seat position ended up being a bit higher than stock ;( I bought a second hand seat rail for the CPV35 from Japan so hopefully it will be on a similar height as the stock. I am waiting my aunt to send it to me so this solution is temporary.
It took me quite me around 12-15 hours across 3 days to finish this project. If I do it now, with the correct direct bolt on parts, I think I can finish it in less than 3 hours.
I noticed that the quality of the seat is not as good as the stock, in terms of back strength. When I accelerate, I can feel my back tilting back a bit (like you can do in an office chair for eg) but lateral hold is quite good. The seating position is a bit too high too. But considering the price of them, I cannot complain at all! It was $100 per seat and $50 each rail. I had to buy another rail for the driver’s side from Japan but it was still around $85. I got 4 point racing seat belts too but could not install it (didn't bother trying too hard).
I consider this mod purely for looks rather than performance because the stock seats were not as heavy as I expected and the back support is only fair.
I hope this helps you if you would like to install new seats!
https://www.sau.com.au/forums/topic/454684-diy-installing-new-seats/
Great work man.
I've been having airbag lights too - and it's probably from my seat harness as the code indicates. For the resistor, say that will "close" the circuit in the driver's seat airbag - would that cause malfunction of other airbags? I don't really care about the driver's seat airbag anyway coz no one ever seats at the back.
If that works I will be heading off to car yards and look for a used v35 seat straight away!
Thanks bluenoir!
Humm... I think the other airbags will work because the system kind of thinks the seat has airbags..
I did the resistor trick on both sides so I guess if you are only planning to do one side, then it will be no problem and the other seat's airbag, pass and drivers airbag will deploy without any problem.
Where can you find a wrecker with V35s? I've never seem a coupe around in VIC eastern suburbs.. saw only one sedan but the seats are pretty crappy haha
Ben, yes you are right. The new seats needs to have ADR certificate and an engineer needs to inspect it and give me a mod plate? certificate? or whatever they call it. But I'm still young and stupid :]
  • Like 1
Great write up mate, appreciate your time doing it, but those seats look dodgy as shit.
Dammed if i'd let one of my kids ride in a car with those in it.
I guess your trying to achieve a racy look on a budget but this is potentially your life your playing with.
Even without considering the lack of an air bag, Id hate to think how they'd perform in an accident situation.
Damm straight they'd be illegal & friggin immoral.
Cheers.
Hey Trevor
I know that haha in fact my car is back with stock seats at the moment (gf said stock are more confy lol).
But what I wanted to show is how to do it on our cars. Next time I go Japan I'll try find some decent real Recaros ;D
Thanks bluenoir!
There are a few in Sydney but parts availability is always a luck thing. I often get lazy and ask JLM to source it for me coz they have contacts and won't rip me off on parts price.
Will check with the tech guys I know (may start looking at my own seats first) to see if this trick will work.
I agree with other guys too on buying Chinese knockoffs - for small things that may be a good idea but a seat is kinda crucial for your safety, especially when our cars are somehow fast.
bluenoir - I see, yeah please let me know whether the trick will work. Thanks for the work of advice ;]
As per my previous post, my car has the stock seats back due to comfort issues with the bucket seat. I know you never know when accidents will happen but since it is so easy to change them over, it is nice to have them in once in a while.
camr33 - maybe because they are reclinable.. full buckets are much lighter, like 8-10Kg. That's of course genuine recaros or sparcos.
  • 2 years later...
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
