For sale
Tallai - Gold Coast 0414596256
Nissan RB26 N1 R33 GTR crate engine long motor to sump with complete intake as shown. Have matching valley cover also available.
Engine has been compression tested 180psi across the board. Leak down tested 0% in each cylinder. With a comprehensive inspection undertaken. Has been used for 18,000km with -5's making 350rwkw on pump fuel at 18 psi. (Turbos not available)
Engine specifications:
N1 block Virgin bore (24U)
N1 Pistons 86mm (24U)
Nissan conrods
R33 crankshaft
N1 oil pump
N1 water pump
ARP Headstuds
Nismo GT500 headgasket
Tomei oil restrictor
Tomei 260 10.25mm intake and exhaust procamshafts
Tomei heavy duty valve springs
Tomei adjustable cam gears
Intake and exhaust ports have been port polished with port matched runners
Gates racing timing belt kit
Note: Removed from r32 gtr, has r32 oil pressure/water temp/air temp senders
$7000 negotiable give me a call or text to discuss can freight Auswide, more photos of motor, dyno sheet, compression results etc available at request
It hasn't been rebuilt, its an N1 crate motor from nissan with 18,000km of use. The head work I don't have receipts for but i can show you photos of the parts etc. Its been removed from a running vehicle and as per post had all checks made. I can more than comfortably offer a start up warranty with it, for a guarantee.
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
