got a bit of a weird problem, at first i thought it was coilpacks going on me due to misfire but it seems to be flat spot rather than misfire as i checked coilpacks (splitfires) and changes to new bcpr8e plugs
randomly when i give it, it would hit 9/10psi and in next gear it would only hit 5 or so psi.
using a turbosmart bleed valve with factory turbo.
can anyone suggest what may be the issue? i've been away from turbo cars for too long so i've checked the most basic things but then its beyond knowledge to further diagnose.
photo below of how the boost tee is setup, is this correct? it came with the car this way, i've only turned the boost turn as it was running 15psi before.
i've read the DIY thread but it seems the guys are getting the pressure source from the cooler pipe after the throttle body with the factory piping, mine doesn't have that
Note: the other line (that doesn't go to wastegate) is connected to the pressure source from the plenum, not throttle body. bottom hose of factory solonoid has been removed,
its probably something simple/silly that i just can't see
Bleed valve could have AIDS. Inconsistent boost is one of their trademarks anyway, but it shouldn't be that bad. Would tend to suggest that it's got something in it (a flake of paint or rubber or something) that is part of your boost control now, and sometimes opens up the flow path enough to stop working as a boost raiser.
OK, for some reason half your initial post wasn't there when I first answered, and there's no sign that you edited it either. Weird. Anyway, having now seen more text and your photos (not that the photos are that helpful, but they do raise some questions)...I think you might have a problem because of the way it is set up.
The boost source for the actuator itself, which in this case is the only boost source connected to your boost controller*, MUST come from the turbo outlet. Either right on the compressor housing (like it is on R32s) or off the hot side intercooler pipe, as close as possible to the turbo outlet itself (like it is on later Skylines). Sure, it can actually come from anywhere upstream of the throttlebody, but let's ignore that and agree that the turbo outlet is the correct place.
IF the boost source for your bleeder is taken from the plenum, you can get really weird results. This is because the plenum's pressure is more or less controlled by your right foot. If that signal is then being fed to the boost controller and then the wastegate, then the wastegate will do lots of opening and closing that it doesn't necessarily need to.
In your photo, those hard lines that run along next to the crossover pipe are not intended to be used for supplying boost signals to anything. They are originally for the charcoal canister. Don't use them for boost control. Especially don't use them for a bleeder.
*You may hear of people correctly taking a boost signal for a boost controller from the plenum. This is necessary for an electronic boost controller that measures the plenum pressure to display on the front panel. It's not directly used for control in most such EBCs. it's really just for information and for setting up the controller. The actual boost signal that is fed to the wastegate is STILL taken from the compressor outlet on EBCs, just like a bleeder.
So I replaced the turbosmart bleeder with a turbo xs one, 7psi sweet, 9psi sweet. Will try 10psi like how turbosmart was and go from there.
So far so good. Same issue as this chap on r31 forums
http://forum.r31skylineclub.com/?topic=31879.0
The turbosmart T's have a smaller hole than most others, for the VQ25 I prefer the Turbosmart, but many have had issues using them on RB's.
The best option is a stiffer spring in the actuator, as close to your desired boost as possible, then bump it up a little from there if required.
i am writing off the turbosmart bleeder as crap, no issues with the turboXS.
I even tried with my mates spare turbosmart bleeder with exact same issues.
However i will tap a nipple into the cold pipe as that is best place to get the pressure source from.
7psi never felt so fun. :D
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
    • Oh, and as for everyone with their fuel economy changes, I switch between E10 and 98 in the company car. Even do when I had personal cars that could run on E10. You know what changed my fuel economy in any noticeable way? How I drove, and where I drove. Otherwise, say on full tanks of just back and forth from work only (So same trips, same sort of traffic), couldn't notice a difference that I can correlate to the type of fuel in use. In the current vehicle, that's over 42L of USABLE fuel. While 98 is all "more energy dense", it also has higher knock resistance as it takes more energy to get it to ignite too. The longer hydrocarbons, typically more tightly bound. So running the same ignition map, can also produce less power, if there isn't enough time to get it all burnt through properly, as yep, the flame propagation speed is different from lower octane fuel to higher (Higher has a lower flame propagation, due to the more tightly bound and harder to self ignite funs. This is also typically where, a vehicle that is designed purely to run on 91 (Whether it be E10 or normal 91) usually sees absolutely no real world difference in fuel economy for the normal man, woman, or dog.
    • We've got some servos around me that have 91 with E10, 91 (no E10), 95, and 98. At those stations the change from 91 E10 to 91, is typically around 8c/L.   But lets not get started on the price of fuel in Oz. It's ridiculous. All the service stations around me, bar one, the price of fuel has been over the $2 mark per litre for the cheapest, 98 being around $2.45. That one service station is a CostCo, fuel from it comes from the same refineries, and makes no pitstops, it runs great, including the 98. In fact, I've had no issues on CostCo fuel, but plenty of issues at other stations!. The CostCo fuel, was $1.65 roughly this week for 94 with E10. $1.88 for 98. Servos directly across from it, $2.10 for 91 E10, and $2.48 for 98. The part I had to laugh at? If I drive multiple HOURS away from Brisbane, say out near Nanango, or Kingaroy, or even out to Goondiwindi, the price of their fuel, is the same as what it is at the CostCo... Oh, and that BP servo at Goondiwindi is HUGE and goes through epic turnover of fuel, so it's not sitting there for weeks going to shit. And what blows me away, my mate is one of the people who drives the Fuel Tanker all around QLD, delivering to all those places. At the same company his previous role was doing the "local haul" deliveries... Same truck, same driver, same pickup point it all comes from. So you tell me, how the hell it is 60c/L CHEAPER for fuel, when nearly all else is equal, except they require a B-Double to drive half a day out of Brisbane, and half a day back, every second day, compared to the delivery that can be under 30 minutes drive from the fuel pickup point... Not to mention, go five blocks down the road, and Ampol to Ampol will vary 30c/L... And I've had this conversation with my mate... The way it's priced, is just typical, pure and utter rubbish... He also does runs from Brisbane, to all over QLD, down to Newcastle, Sydney, Nowra, Melbourne, Geelong, and even out to parts of the NT depending on the companies needs. His main stuff is all the longer distance away from home for a few days at a time, then when he's back, he loves to just pickup extra shifts wherever he can in whichever truck, hence all the weird different places.   Oh, as for getting E10 into all the fuels in Australia... It was very quickly highlighted, that we don't have enough biomass available to use to make E10 sustainably like they require, and it would dramatically cut into our, and the worlds food chain supply...   I vote we all just start running on liquid methane gas... Plenty of that just getting tapped off at tips from underground decay... (Note, this is pure just stupid commenting. I could very easily highlight the reasons its not a good idea especially on scale...)
    • Am I correct in assuming that the R35's are getting the classic skyline haircut off the odometer?  Quick search on carsales, there are 33 08 and 09 GTR's for sale, only 2 of them have more then 100,000km's on them (116,075 and 110,000 respectively).  And somehow there are about 25 for sale with around 60,000kms? Looks like the classic skyline haircut to me =/
