So they're getting old now, and some parts are becoming hard to find and will become harder as time goes by. If you're going to keep your older Nissan what parts should you start collecting while you can? Things like suspension, clutches, brakes etc are all readily available after market, but quarter windows, window trims, rubbers, etc need to be from Nissan or off another car if you can find one that isn't as shagged as the part you took off yours.
So, what is a good list of things to start collecting?
https://www.sau.com.au/forums/topic/455403-stockpiling-spares-32r/
Well for the sake of conversation humour me and assume both are catered for. I think if you're selective and look out for second hand parts as well as new then it's may not be that bad.
The original question was what spares do you need to start accumulating that will dry up as time goes by. I'd guess a bonnet and front guards among many others. Also little bit's and bobs. Let's have
I wouldnt keep spare guards and bonnet 'just in case' I need them one day. They take up alot of room and may never be needed
Id stockpile gaskets and clips etc personally. I have a small collection of this stuff at the moment. Sensors and shit as well would be a good thing
Things that are likely to fail
At the moment its easy to get most parts you might need. I bought the clips for the reat seats and the harness + cap for the headlights of my r33 the other day relatively cheap
  • 4 weeks later...
I think that it really depends on how long you intend to keep the car.
I love my R33's and since I retired I have been collecting them to the point that I currently have a R33 GTR VSPEC, two Series II coupes, a Series II sedan and I have just acquired a C34 Series II Stagea (all registered).
From my experience with other cars you have to identify what components either fail on a regular basis or have a specific service life and identify a supply point for them. You also need to identify components that Nissan charge like a bull for (e.g. door rubbers at $1,000 per door) and stockpile good second hard parts to cover these components.
Aftermarket parts also become hard to come by as demand dries up and shops stop stocking these parts. Good buys are available when shops are selling up parts that have been on shelves for years and are not moving.
You also have to identify components that are model specific and not interchangeable across the entire model run (e.g. I have a spare v-spec diff).
The biggest issue then becomes storage. How much is enough and when is it too much? There are a lot of small parts that fail on a regular basis that are easy to keep spares of (e.g. electric window motors) but drivetrain, seats, panels and spare shells take up a lot of space.
I have at least one for just about every R33 component both 2wd and AWD with a collection of most body panels both new in boxes from Nissan and good quality spares plus a few shells for other structural parts.
For some reason my family think that I have an obsession with my R33's - please tell me it is not so.
Definitely an obsession happening there, go for it.
But you're correct, storage is the problem.
As mentioned, body panels are hopeless to store and there's always the danger something will fall on them. Best place for body panel is on a car. In fact best place for everything is on a car.
But door rubbers etc are already at insane prices and will become more so in future. Not an easy item to store properly in the hope it's not going to disintegrate once you open the packet.
Imagine paying around $1000 for a 32 dash only find 10 years down the track it's developed bubbles in your storage, would not be happy.
I'm concentrating on the expensive plastic interior bits as very few 2nd hand will still have all their tabs.
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
