Hey had this split the other day ..started pissing out coolant. Once it stopped I replaced it with a similar hose. Just wondering what does it do? Is it a heater hose? Can I block it if I'm deleting the heater?
Edited by boobeedoobee
It joins up with the factory coolant hard lines for the twin turbo setup that travel along the top of the heat shields to the back of the head (splitting down into the turbos also).
Also didn't you create another thread about deleting the heater and it was suggested by multiple people to just replace the hose(s).
Unless you're pulling the entire loom/engine out and building a dedicated track car I don't see the point in deleting it as if you need to use it on for a registered car its required.
Edited by breaker1845
Right so there not heater hoses thanks. Btw you don't have to have a heater in the car for it to be registered just something that can demise the windscreen. And there are other options for that. The way I look at it is that my car is driven more on the track then it is on the street so couldn't care for a heater or airconditioning as the whole time I have owned it I have never turned either on.
FFS. The heater hoses are clearly and easily findable from the two points, right next to each other, where they pass through the firewall. From there you can follow them to where they go on the engine with a torch, an uncrossed pair of eyes and maybe a pair of fingers to follow them where they might pass out of sight. On lesser RBs they both pass immediately behind the head and then into the mess of coolant plumbing under the back end of the plenum. The details will be different on the 26, but the general route will be the same.
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
