Hmm ok replaced the pcv with a new one and the problem still exists, but as not as much.
Again., oil is sucked in on coasting down long hills, then big plume of blue smoke on accelleration.
I saw back in a 2010 thread, JDM_spirit blocked off his pcv ,the problem went away and the car performed normally.
So I'm gonna try it too.
I'm burning 1 litre of oil every 5-6 weeks.
My mechanic does think it's the valve stem seals and told me to start saving up.
I do not like the sound of that..
He pointed out it's common for cars around 10 years old or more that have sat around for long periods of time.
The seals are neoprene and dry out.
The previous owner said he hardly drove it in 6 months as he had a company car.
Then additionally the time she's been on the boat coming over from Japan.
Anyone here done their seals or guides ?
Would like to have an idea before I commit.
If the head has to come off I may as well swap over the turbo at the same time.
cheers
Turbo's with ruined rear bearings will sometimes blow smoke on decel. Can you drop the dump and see how much play the turbine wheel has? More likely that than the stem seals, but who really knows until someone picks up a wrench...
Yeah true, wish I had more time to tinker myself.
Another thing to consider is the oil only seems to enter when the car is facing down hill, driving and parked.
If I park facing up hill, there's never any smoke on start up.
Where's the pcv, toward the front or back ?
cheers
Yeah but wouldn't the oil immediately enter the manifold if it's the turbo bearing.
So there would be smoke whilst rolling downhill or gearing down and there isn't.
Only once I touch the accellerator.
It's like the head doesn't drain quick enough when going downhill.
Thanks for all the feedback.
Your symptoms are typical of oil getting past the rings, although the valve stem seals are still a possibility. How about doing a compression test and/or a leak-down test?
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
