  • Replies 130
um nah only had the car 4 2 weeks..hacnt had chance 2 get it dynoed......an yeah soon as i touch the throttle it blowws LOTS of smoke...an i mean LOTS.......it dont wait secons then come out..its as soon as u touch the throttle i comes out....
um i was gonna try 2 drive it but soon as i gave it sum gas 2 get going it jus blew like so much smoke out i wasnt funny i figured i was best left off......
an i dont know if turbo is blown or not..im gonn pull it off in the mornin an c.....how can ya tell by lookin at it.......an i think it is my turbo cause the cooler is filled with oil......
Your answer Chris
if its thrown the exh wheel of the turbo it wont smoke hard from a cold start untill the exh gets a bit warm and the oil starts burning in the exh housing and exh(couple of minutes). Happened on mine, spat the exh wheel out, no real smoke till it warmed up a bit and then massive plumes of white smoke out the exh under throttle
im assuming if its rings it'll smoke whenever theres pressure in the cylinder/s regardless of engine temp
ok then,
i have gone out 2 c the mess again this morning...... :) um i started it an put the foot down....the turbo spooled up an it blew whitey grey smoke......so wat is me best answer as 2 wat 2 do now.....??? thanx guys
white smoke is if the turbo is blown generally, blue for engine, black if ur running very rich.
Your basically describing white smoke as far as i can tell. (whitey grey). Does the turbo whine at all on boost? I'd get a bov as well even if it is stock. It may be stuffed rings but from what i was always told, blue smoke equals engine, white equals turbo. I suggest putting a bov on and borrowing another turbo from someone and giving that a quick try. I'd clean everything out first though.
Did u buy the car from anyone off here?
no smoke under the oil cap......
no smoke newere exept im masses out of my exaust... an turbo is throwing LOTS an mean LOTS of oil straight up the intake pipe an into the motor.....i took the cap of were the BOV is meant 2 b.....an as i reved it it threw like u buket load of oil out of the hole....
personally with how it looks..i reakon its a turbo seal has gone.....an its jus throwing all the oil up the pipes into the motor then the oil is burning an thats y it has so much smoke coming out....
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
