  • Replies 130
um nah only had the car 4 2 weeks..hacnt had chance 2 get it dynoed......an yeah soon as i touch the throttle it blowws LOTS of smoke...an i mean LOTS.......it dont wait secons then come out..its as soon as u touch the throttle i comes out....
um i was gonna try 2 drive it but soon as i gave it sum gas 2 get going it jus blew like so much smoke out i wasnt funny i figured i was best left off......
an i dont know if turbo is blown or not..im gonn pull it off in the mornin an c.....how can ya tell by lookin at it.......an i think it is my turbo cause the cooler is filled with oil......
Your answer Chris
if its thrown the exh wheel of the turbo it wont smoke hard from a cold start untill the exh gets a bit warm and the oil starts burning in the exh housing and exh(couple of minutes). Happened on mine, spat the exh wheel out, no real smoke till it warmed up a bit and then massive plumes of white smoke out the exh under throttle
im assuming if its rings it'll smoke whenever theres pressure in the cylinder/s regardless of engine temp
ok then,
i have gone out 2 c the mess again this morning...... :) um i started it an put the foot down....the turbo spooled up an it blew whitey grey smoke......so wat is me best answer as 2 wat 2 do now.....??? thanx guys
white smoke is if the turbo is blown generally, blue for engine, black if ur running very rich.
Your basically describing white smoke as far as i can tell. (whitey grey). Does the turbo whine at all on boost? I'd get a bov as well even if it is stock. It may be stuffed rings but from what i was always told, blue smoke equals engine, white equals turbo. I suggest putting a bov on and borrowing another turbo from someone and giving that a quick try. I'd clean everything out first though.
Did u buy the car from anyone off here?
no smoke under the oil cap......
no smoke newere exept im masses out of my exaust... an turbo is throwing LOTS an mean LOTS of oil straight up the intake pipe an into the motor.....i took the cap of were the BOV is meant 2 b.....an as i reved it it threw like u buket load of oil out of the hole....
personally with how it looks..i reakon its a turbo seal has gone.....an its jus throwing all the oil up the pipes into the motor then the oil is burning an thats y it has so much smoke coming out....
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
