New Motor Making No Power
Huzqld
 Share
Hey guys.
Went for the tune of my 25/30. We cant get it to make hardly any power. And compared to my old slap together SOHC setup, it makes less power less torque and it all happens later, Also its starting to knock up high at anything over 19psi (98ron).
We suspected cam timing so degreed the cams in again, (found the exhaust cam 15 degrees retarded). intake cam is 4deg retarded but cant adjust that with out pulling the gear off.
Set the exhaust back to 115 deg *standard cams. It made it better but not a whole lot better.
Motor specs
Rb25/30 Neo 9:1 comp (old motor was in the 7s)
forged pistons, rods
CPC plenum
steam pipe manifold gt35
3inch exhaust 1 muffler no cat
660cc injectors
vipec v88
Standard head with upgraded springs and retainers
still has vct but didnt turn it on yet.
Exhaust, turbo and intercooler plumbing is exactly as it was on old motor.
Here's a pic of the run in comparison to the old sohc.
Any ideas?
Hate that! I'm tipping you had mentally prepared yourself for a big increase! Not that a forged engine will necessarily make more power, just stay together for a bit longer.
I would presume they have checked spark timing?
How confident are you of the compression ratio?
How long has the car been sitting during rebuild- not old stale fuel?
Not sure if it's possible but VCT not locked over advanced seeing not connected?
I'm sure there are other possibilities but that's all I can think of. The knock is a concern and hopefully leads to the diagnosis. It shouldn't be pinging on 98 with 9:1 comp.
Good luck!
Well yeah I was looking for at least an extra 30-50 hp. Going from a single cam head to a twin cam head.. The single cam head only had a baby cam. I expected the boost and power to be on earlier and make more torque and power in general.
Yeah we double checked ignition timing. Pretty confident on the comp, its a tad higher then 9:1 i have it here somewhere.
Fresh fuel. And Ive done over 1000ks on the motor with a soft tune.
Not sure on the vct one but I thought if off its just normal and energized it will advance? Even being advanced you would think the power would be on alot sooner
Ok not sure where to go next with this thing.
Got the cams set at In 121. Ex113
Gets to about 5000rpm and starts detonating even with only 13 degrees timing on only 17-18psi, still making no power or torque.
Afr are good
Compression is 170-165 across all 6.
It has around 2.5 psi exhaust back pressure
And 2.5psi pressure drop from hot side to manifold
Head was decked down to 46cc to get the comp up a bit.
To much compression?
Is it possible the vct gear is stuffed and causing the cam timing to move around?
It's not a bad batch of fuel by any chance? Or a servo that's claiming to be selling premium and actually shoving standard down the the hole? Cause that's become a common issue
  • Like 1
I guess that is possible, but I doubt it is the case..
Here is the pistons I am running and a pic of combustion chamber.
Thinking about putting some pon-cams in it to try help it breath a bit better
Edited by Huzqld
Is it me just getting old but are those pistons dished in the picture?
I hope not because if they are i can assure you your not getting 9:1 compression.
For some reason i see a 5-9mm ring at deck height around the piston, then they dip down lower.
Is that right?
If so then i can see lots of Det causing pockets right under the quench pads.
Did you round off the valve relief edges on the pistons?
Its a really weird piston shape for those heads, what pistons are they? Part number?
Maybe they are domed, im seeing dished, could be the way the pic was taken......
Cam's can only go one way due to the VCT gear on inlet.
Yeah you are seeing correctly, they are dished. 9cc. (Dished because neo chamber is alot smaller than the normal 25-26 head
They are a wiseco piston, here is a close up. Did not do anything with the pistons...
It's seeming more likely these are the issue with the knock.
Edited by Huzqld
I'm pretty confident on the compression, calculated while we were building.
Is there anything I could get done to the head to fix the issue?
Really don't want to have to pull the motor back out to replace Pistons and get it all balanced again. I think if I have to go that far I'll put a 26 head on it while it's out.
How sure are you about the 9:1 compression? You planed the head to get the compression up and then dished the pistons to get it down? Do a compression reading and see what you get
I don't know what your cam settings are - they seem a prime suspect.
I already had the pistons as I bought all the parts off a guy that didn't go ahead with a build. I was going to just run somewhere in the 8:1 range compression but was advised against it, so decked the head to get to 9:1.
Did a compression test and got 170-165 PSI across all 6
Cam settings are. Inlet 121deg- Exhaust 113deg
 Share
