My 32 gtr has a Nistune running 310rwkw. It has e85 1000cc injectors hks gtss turbos dumps exhaust.. from what I have read I have now maxed out my afm. I was thinking of buying the nismo afm and getting a haltech ecu. Is this a good option or do I just need to upgrade my afm?
Tuner can tell you.
Once you know, get rid of AFM and go MAP.( adaptronic or haltech plug in )
That said, you can still go beyond the limits of AFM's
EDIT
I remember Matt saying from there testing the limit is around 370kw for a single z32
Could try a HPX maf, but i would just replace the ecu if you are looking for over 400kw
Edited by jay-rod
Either you upgrade the AFMs to Nismo and you retune and get a better result, probably to the point where you max out the injectors/turbos and other components become limited.
Or you get rid of the Nistune ECU and buy another ECU and go with a MAP based sensor and forget about AFMs all together and tune the new ECU to the point where injectors/turbos and what not will be limited.
Measures the absolute pressure, which in turn allows you to mitigate the negatives of a AFM.
Eg, reverbaration, dirty afm affecting the signal, removes pretty much any limit on max airflow.
Atmos based blow off valve will not stall an engine
Comming off throttle will be alot "Smoother"
A pressure line will run to a sensor ( think of it like a boost sensor ).
This sensor will either be external, or internal to the ECU.
Most plug in ECU's use internal map sensors, and would be what you want.
You then remove the need for a AFM, and take them completely out of your engine bay.
And run a single boost line to the map sensor
Edited by jay-rod
  • Like 1
Thanks it seems like this is a common question as to which is better? Afm or a plug in ecu which eliminates the afm? The general consensus leads to deleting the afm and spending the money on an ecu? A pair of nismo afm is going to cost 800ish I'm thinking this could be money better spent on an aftermarket ecu
You can't tell that your AFM and Nistune is "maxed out" by reading. Your tuner will tell you when that happens. How many turbos and how many afms do you have? I doubt anything is "maxed out" at 310awkw..if your tuner can't tune it because of the afms get a couple of RB25 afms.
Yes a Link would be great if money is burning a hole in your pocket but the ecu, map sensor, temp sensor, installation and tune won't leave much change out of $3k
won't a haltech platinum pro plug and play eliminate the need for any of those?
Just bought a hpx airflow meter from Nistune. All going well it will be getting tuned on Friday. Nistune say its goo upto 800hp.
What did they cost for the pair if you don't mind me asking?
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
