Long story short, wasnt paying attention in car park - looking at reverse camera and not out the windows. Happened at Westmead Childrens carpark on split lvl.
so will cost me roughly $1515.80 to fix where my insuarance will only cover $1000 and I have to foot the rest. Currently no wreckers have stagea rear windows.
Is this normal price coming from nissan brand new including install. 6-8 week leadtime.
Sorry not new here - just cant get into my old account.
Bangahh since 2002, I have tried Ebay - might as well bite the bullet. thanx
$1550? For twice that you can buy a running M35!
Dont really want to spend the coin, Insurance company allows one free glass replacement a year capped at $1K
Going thru insurance preferred agent, apparently none in sydney wreckers. Im told.
Unlesss someone has one in Sydney - I'll call around just to make sure there is none before i order off nissan.
It's almost as if you didn't read that Scotty has one that you can buy for a shiteload less than buying through Nissan?
I bet you could have it shipped from Melbourne to Ryde pretty easily too.
Why do people want to do things the hard way?
  • Like 2
If you've got $1K of insurance money to spend, I'll personally drive one to your door, lol.
  • Like 1
thanks guys for your response, problem with shipping glass / fragile item is that most normal transport company wont gurantee insure it unless you use a company that specialise in fine arts ( apparently ) I have used something similar for transporting Servers and they arnt cheap.
BTW - I did give Scotty a call.
The thought of driving to Melb myself did cross my mind, but im dealing with the insurance preferred agent. This is the first accident i have had in 15 years ( 10yrs in R33 and 4yrs in M35 )
I could have met you at the border and done the dodgy deal in a truck stop. lol.
With enough bubble wrap or blankets I am sure it would have made it fine. This way you would have got the whole window in the frame with switch, hinges etc, not just the glass.
  • Like 1
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
