Hi All,
I am wanting to swap my full bride look interior in my R32 GTR for full stock.
I have Bride reps with the rails, door cards, rear cards and the rear seat has been reupholstered.
Stock seats must be in great condition.
Inbox me if you are interested (Vic only).
Thanks
actually, let me know how much you would want for the whole interior.
i have the door trims and rear trims from my gtr aswell as gtst front and rear seats you can have so you are mobile while you look for decent gtr seats.
again let me know.
Door cards and rear trim is still available for swaps,
All seats are now gone.
Let me know if you would like to swap for r32 GTR stock door cards and rear trim.
Hey buddy I have a full set of front and rear R32 gtr seats in good condition
Let me know if u want to swap thanks
hi mate, im after some front seats, ive got two bride lowmax reclinables available.
interested in a swap-cash type deal
text me 0422816917
Nick
  • 1 month later...
Anyone want to swap the door cards and rear trim for stock r32 gtr ones this weekend?
They are already out of the car.
(Seats are all gone.)
Let me know.
Cheers
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
