Just my thoughts after having the car for 3 weeks.
Firstly great looking car nice rims chrome around the windows looks nice. Only fault no driving lights on front bar should be standard on all sp models. Secondly top engine lots of power smooth acceleration. Theres been a few post about fuel economy been not so great iam getting 520klm per tank which is unreal considering the performance you have on tap. Good quality interior nice layout love the music box. The standard audio is actually not the bad good bass from the front speakers.FAULTS to me are the steering seems quit heavy as soon as theres a defect in the road the car will pull to that side in a hurry which can be a pain. Suspension is quit firm can get very bumpy at times nissan should have had a setting for comfort and sport. Saying that it handels great around corners. So all up I realy like the car but its not for me I think it was more of an impulse buy and will be selling it soon. Hope to read some replys on other owners and there thoughts
https://www.sau.com.au/forums/topic/456307-pv36-review-after-3-weeks/
At first I was like :happy:
Then I was like :woot:
Afterwards :unsure:
And now :(
...why are you selling? PV36 is where it's at for the money!
Around the 4-5k mark for a decent system including a decent management system like Accuair. So it's not cheap.. but it will likely make the ride softer than what you currently have, plus then you can run whatever height you want. Need air tank(s), compressor(s), bags, lines from compressor to tank, lines from tank to bags, fittings, management system.
It's technically only legal if you also have the auto levelling system installed with it (and probably an engineers cert), however this will not allow you to adjust it on the fly, only when parked. I think driving mode is then set at the minimum legal height for your car too.. which doesn't sound overly fun.
If you don't go around slamming it and pumping it while driving then it's not likely that you will get done, but if you're spotted playing with it, or hard parking somewhere with it on the ground then you may get some unwanted attention haha. But it would be tempting!
www.accuair.com
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
